the worst luck
Old Feb 10, 2010 | 08:12 PM
askmenomore's Avatar
Default the worst luck
Well... Last month a rock fell out of a back of some truck and i ran over it and it killed my rim and tire. This month waterpump went out. Now i turn the key......nothin happens, turn it agin......nothin, turn it agin starts like its new. ooo my luck, when will it end.
Old Feb 10, 2010 | 08:29 PM
Default Re: the worst luck
Wow, sounds like a case of If it weren't for bad luck, I'd have no luck.
That said, I would start with the battery. How old is it?
Old Feb 10, 2010 | 08:33 PM
its the factory battery, i put it on the charger and it was 100% but i think its just lost its cracking power.
Old Feb 10, 2010 | 08:41 PM
04Fire's Avatar
What year do you have... it could just be a bad connection. Are the battery terminals clean?
Old Feb 10, 2010 | 08:50 PM
32krazy!'s Avatar
always start with codes check then electrical then mechanical. it will save you some headaches in most instances
Old Feb 10, 2010 | 09:04 PM
they are clean, its a 2005.
Old Feb 10, 2010 | 09:35 PM
musicnsurf's Avatar
uuuuhhh, you're lucky you own a crossfire?
Old Feb 12, 2010 | 01:10 PM
well i believe its the starter the relay control madule doesnt look bad and the battery is good. lifes just great one thing after another
Old Feb 12, 2010 | 01:17 PM
It can always be worse, trust me. You are trying to figure out how to fix your German sports car, many others are trying to figure out how to feed their families. Car troubles suck, I am going through some of my own at the moment, but take a breath and realize you are a lot luckier than most of these other poor SOBs out there....
Good luck!
Old Feb 12, 2010 | 01:33 PM
JHM2K's Avatar
Good luck!
Well-stated...
Good luck with the car man. Stay positive.
Old Feb 12, 2010 | 01:35 PM
Good luck!
I got laid off monday. so i guess its time to sell the old fire. i give up
Old Feb 12, 2010 | 01:57 PM
There is no way a four year old battery is "100%". Replace it, then visually inspect the solder on the Relay Control Module.
Sorry about the layoff. This economy is in trouble.
Old Feb 12, 2010 | 02:59 PM
AlG's Avatar
AlG
Crank sensor?
Old Feb 12, 2010 | 03:10 PM
ok wheres the crank sensor because its not the starter. i turn the key and theres a clickin soun coming from the back of the intake where the engine cover connects to the intake the plastic piece.
Old Feb 12, 2010 | 03:32 PM
it will start every once in awhile and it acts fine no check engine light or anythig acts fine.
Old Feb 12, 2010 | 05:29 PM
old batteries can be a problem...did you take to auto zone, or someplace like that, and have them put a "load" on it to see if might have a dead cell? There is a lot stuff about the "Crank Sensor"...just use the search feature and read away...install instructions and all are on there....good luck
Old Feb 12, 2010 | 10:02 PM
well im back in action, it was the battery and the crank sensor. $170 for the battery and $72 for the sensor.
Rob M
25
Nov 5, 2015 05:23 AM
PA/XFIRE
Sep 5, 2015 01:25 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
xzmilan
Jul 22, 2015 10:40 AM
andrew
Detail Shop
Jul 25, 2006 09:39 AM
