Engine Swap Ideas
on
Re: Engine Swap Ideas
Originally Posted by GettinIt
LS1!!!!!! Did it in my RX7... and i kick myself daily for selling that car.. I plan on doing it to my XF... one day...
Chuck, can I ask why no Mercedes? Is it simply a financial requirement or is there something deeper behind it? (IE the lack of support and high cost of doing the unknown)
I think this would be sweet...............
Ferrari 360 Long Block Engine + Transmission + Harness : eBay Motors (item 220557741826 end time Mar-18-10 13:45:19 PDT)
A little pricey, but the sound would be AWESOME!!!!!!!!
I see some good ideas here, a couple I have been considering. The only electronics I am concerned with keeping is the keyless entry/security system and fuel gauge. Our dash is so simply laid out putting a new tach or speedo should not be a problem.
One of the crazier ideas I have been toying with is a turbo slant six. I've had a couple(not turbo) and its a super strong reliable motor.
Here is a couple examples, I'm pretty sure they are running stock bottom ends.
YouTube - 11 second turbo valiant slant 6
YouTube - Turbo slant 6 - 1/4mile pass
A friend of mine has a last gen 7 with an LS1 swap, headers, tune, etc and that car is absolutely insane on a track. Can't wait to get this snow off the ground
Let me know if you have any question on the electronics side but I think you're gonna need to leave the electronics in there and just run everything in parallel. Cam or crank trigger inputs on the stock ECU will give you RPM, stock sender in new engine will give you ECT, fuel and speed won't matter as those will still be using the ECU and the factory senders/sensors, kill the ESP/BAS/TC by disconnecting the YAW and SA sensors and you should be set. granted this is paraphrased but you get the idea.
The main problem with a 360 engine is the fact that they don't make much power............and you don't want to know how much mods/maintenance cost for that powertrain.
on
Originally Posted by 32krazy!
with out a benz driveline it turns into another bankrupt mopar car.
no offense but thats the main draw to these cars.
