Hood Design Issues???
Old Mar 29, 2010 | 08:59 PM
SoftballJunnkie's Avatar
Default Hood Design Issues???
Just wondering if u guys have this same issue. When I had my crankshaft sensor go out I opened the hood and shut it and noticed I had a small dent in my hood. After inspecting it some more I noticed one of the caps on the passenger side (coolant, oil, etc) was rubbing against the hood liner where the dent was at. Has anyone had this problem. Looks like the cap sits way to high.
Old Mar 29, 2010 | 09:03 PM
SRT-6 Steve's Avatar
Default Re: Hood Design Issues???
Not sure but one of my pet peeves are people letting the hood slam down from several feet in the air. This is not necessary and maybe it may have flexed that much during closing??????
Old Mar 30, 2010 | 02:34 AM
I cant stand slamming my hood 5 feet in the air either. I just noticed the cap is not designed properly and its rubbing the hood liner.
Old Mar 30, 2010 | 03:11 AM
Infinite's Avatar
never had an issue
and you dont have to slam it from its fully open position
get it about a 1ft from closing, lift up and let go real quick
or i close it and press it down the rest of the way.
no need for slamming.
Old Mar 30, 2010 | 05:05 AM
No problems myself but the hood liner does sag a bit and rubs on the engine cover. The worst point of contact is the area just behind the Chrysler winged logo, it actually leaves a mark. Also the clips along the rear edge of the hood that hold the liner in place can touch the top of the engine cover if they are not bent close to the hood.
There is not much room under the hood, a 3/4" thick piece of wood on the battery will prevent the hood from closing.
If you have doubts about clearance, try a piece of wood and try to shut the hood gently.
Old Mar 30, 2010 | 01:45 PM
MikeR's Avatar
I have never seen or heard of anyone having a problem with any of the caps hitting the hood..... engine cover rubbing the liner, yes......
Old Mar 30, 2010 | 02:33 PM
hcarter's Avatar
Sounds like the radiator coolant bottle lid is too high bottle may not be down far enough (snapped into place with rubber grommet) maybe someone had it out at sometime and did not get it snapped back in,,,,but I have never heard of this problem either Strange Take some pictures and post so we can take a look I would like to see what is going on with your hood
Old Mar 30, 2010 | 11:12 PM
+fireamx's Avatar
Broken motor mount???
waldig
Jul 31, 2017 09:46 AM
waldig
Sep 2, 2015 11:02 AM
Tp'sfury
Aug 13, 2015 08:20 PM
waldig
Jul 29, 2015 06:54 AM
waldig
Jul 20, 2015 08:10 AM
