Please Help!!! Possibly a serious problem
Tonight after i got off work at midnight I was showing a buddy my new HID's that i just put in my 04 Limited. I started it up and it idled for about 30 seconds and then i heard an odd thud noise. I started backing out of my spot and realized that i didn't have any power steering, it was about that time that it dawned on my that something was wrong. I imediately shut the car off and popped the hood. I pulled the engine cover off and saw that my belt had come off, I picked it up and it was covered in oil. I went and got my flashlight and saw that the front of my engine was covered in oil too. It appeared that it was coming from the oil filter housing because the sides of that was dripping with oil coming from under the cap. So i got a ride home from my buddy, and as i sit here typing my poor lil car is sitting in my works parking lot soaked in oil. Does anybody have any ideas on what may have happened? or why there was oil pouring out of my filter housing? I'm very concerned about my car........Thanks for the help.
Re: Please Help!!!! Possibly a serious problem
Did you just change your oil? Either you didn't tighten the oil filter cap down tight enough, or you installed the large "O" ring on the filter's bayonet in the wrong position.
Ok, I just read your other post, and you didn't do the oil change, but a mispositioned "Large" O ring is the probable culprit.
It looks like there are two positions you can install the large O ring on the bayonet. The most obvious position should be the very top groove, but in reality, the correct position is one groove from the top.
Bring lots of rags to work tomorrow, and maybe some degreasing spray and wipe off the front of the motor, (especially the pulleys). Unscrew the filter, and put the O ring in the right position and replace it. I don't know if you will be able to get the belt clean enough to reuse or not. Top off your oil level, and check it with the dipstick.
Re: Please Help!!! Possibly a serious problem
Apparently the dealer that I bought the car from didn't install the oil filter o rings right, just like you guys said. Just took it 6 months to shift completely to the wrong spot i guess. So after my mechanic was done with it i've got a new oil filter with the o rings properly installed, a much needed oil change, and a new belt. After it was all said and done my car is back on the road and my pocket is 250 bucks lighter. Thanks everyone for helping and putting my mind at ease.
Originally Posted by oledoc2u
Or.......while installing the HIDs a helpful hand messed with your oil filter and turned it....I know people like to touch our toys...either way, follow the advice given, including replacing the belt.....expensive HIDs...huh...
KDW4Him
18
09-01-2021 05:47 PM
Adrian_X
11-09-2017 08:49 AM
Freezer
08-06-2015 07:24 PM
