instrument lights and heater fan dead simultaneously
Old Apr 26, 2010 | 11:23 AM
tabcontrols's Avatar
Default instrument lights and heater fan dead simultaneously
I have an o4 coup. If I turn on my headlights prior to inserting my ignition key, the instrument cluster backlights come on. When I insert my key the lights are still on. When I turn the key to start, the lights in the cluster go out. while the car is running, the lights are out and the heater fan won't run. If I turn the engine off the lights stay off on the instrument cluster. As soon as I slide the key out of the ignition, the cluster lights come back on. I have checked the fuses. They are fine. What could the problem be?
Old Apr 26, 2010 | 01:22 PM
Goldwing's Avatar
Default Re: instrument lights and heater fan dead simultaneously
Sounds like a short in the ignition circuit. What happens when you insert the key and go to the accessory position (i.e., turn on the ignition but do not start the car)?
Old Apr 26, 2010 | 10:29 PM
When I turn the key to the point of resistance(The point you go just prior to engine starting), the cluster lights go out. They won't come back on until I pull the key out of the ignition.
waldig
Sep 2, 2015 11:02 AM
waldig
Aug 14, 2015 01:02 PM
Ralph289
Jul 26, 2015 12:52 PM
PitMarshall
Canada
Jul 12, 2015 10:32 PM
joethejeweler
Jul 7, 2015 08:58 PM
