Rotor Remove Help!!
Old Sep 3, 2010 | 12:13 PM
Crossfire725's Avatar
Default Rotor Remove Help!!
is their a trick to get the rotors off or somthing im forgetting. im doing the rear now and its not coming off. the top is real loose and the bottoms not moving at all. please help. same for the front?
Old Sep 3, 2010 | 12:37 PM
OKC-XFR's Avatar
Default Re: Rotor Remove Help!!
There is a lock screw in the face of each rotor - some are hex (allen) and some are torx, depending on your car. Be careful with them, they are kind of soft...you can see it in this pic: https://www.crossfireforum.org/galle.../47751/cat/500
Also, the emergency hand brake must be released to remove the rear rotors.
Old Sep 3, 2010 | 12:52 PM
Germany's Avatar
YEah, if the screw is out, the onl trick is a HAMMER.
Took Tazz and me a while to get one rear rotor down because of rust, so we used a hammer and a PVC tube extension.
Old Sep 4, 2010 | 07:25 PM
Larry Hitze's Avatar
Originally Posted by OKC-XFR
There is a lock screw in the face of each rotor - some are hex (allen) and some are torx, depending on your car. Be careful with them, they are kind of soft...you can see it in this pic: Message - CrossfireForum.org Gallery
Thanks for the picture - I copied it for my files if thats ok. I didn't know that ( set screw ) about the rotors. Handy when I have to change mine. Fronts not that way?
Old Sep 4, 2010 | 10:56 PM
OKC-XFR's Avatar
Fronts have them, too... Message - CrossfireForum.org Gallery
Old Sep 4, 2010 | 11:04 PM
Ok Thanks for the info.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
leaddog2015
Sep 26, 2015 08:23 PM
