clutch won't engage
Old Oct 11, 2010 | 11:44 AM
cbccadet2002's Avatar
Default clutch won't engage
I was driving home last night and on the off ramp my clutch was super super stiff. I only live about a mile away so i coasted her home. Now i can shifts through off of the gears but i cant get any movement. Any advice? Im hoping my clutch is roached, but can only go with the worst right now. thanks
Old Oct 11, 2010 | 02:45 PM
Goldwing's Avatar
Default Re: clutch won't engage
Not a lot to go on, but I doubt it's your tranny since you can shift the gears. I would suspect clutch, throw-out or pilot bearing, or linkage. Take it to a shop that specializes in foreign (esp German) car transmissions. If it's any consolation, a failed clutch should not get stiff, but would allow the engine to rev with no corresponding increase in speed.
Old Oct 11, 2010 | 02:57 PM
Ya, its kinda hard to explain really. There isnt much resistance on the clutch pedal when i press it to the floor. I can feel a "step" about half way in the travel.I topped off the fluid, but still nothing. I dont see any fluid leaks or puddles so i'm thinking its a linkage or something inside the housing.
Old Oct 11, 2010 | 03:03 PM
shapeshifter309's Avatar
Wait... you topped off the fluid? What fluid? I thought our transmissions were sealed from the factory. I don't think we have anywhere to even fill them.
Old Oct 11, 2010 | 03:04 PM
Mileage, year, condition, regular maintenance, etc.?
We need lots more info.
the fluid in the reserve.
Old Oct 11, 2010 | 03:06 PM
sorry. its a 04 hard top 6 speed. has about 84k on it. I normally dont run it very hard, but i had it up there last night. I've only had it about 10 months, so the only real maintenance ive done is oil change.
Old Oct 11, 2010 | 10:03 PM
Bladecutter's Avatar
Hi Cbccadet2002,
Your clutch issues sound exactly like what Bat experienced earlier this year.
Look in this thread for an explanation, and pictures of the dead parts:
https://www.crossfireforum.org/forum...-colorado.html
BC.
Old Oct 11, 2010 | 10:19 PM
Originally Posted by Bladecutter
Hi Cbccadet2002,
BC.
Unless you know something I do not then I can see no similarities in the two cases.
Clutches are for sissies anyway.
Old Oct 11, 2010 | 10:36 PM
I know ALOT of things you don't know, and the number one relevant one being that Bat's clutch issue sounds EXACTLY like the above descriptions from the original poster.
Bat's clutch, when pressed, was really limp, until nearly the very bottom of the travel, when it was practically rock hard, and only about 1/2 an inch of travel.
When trying to actually move the shifter from one gear to the next, it was rock hard, like you were fighting with an arm wrestler in order to get it into the next slot. Reverse was nearly impossible with the engine running.
With the engine off, shifting through the gears was considerably easier, but the clutch action was still screwy.
After the replacement, the clutch and shifter action is better than when she first bought the car.
And remember, all these issues were with just over 9k miles on her car.
BC.
Old Oct 12, 2010 | 02:36 AM
BC.
I'm having a hard time figuring out what he says in the two posts. One minute its stiff and next its loose. He drove it home and now it will not move. So now I guess its jammed open and not clamping down.
Old Oct 12, 2010 | 02:41 AM
When i came down the off ramp on the interstate is was extremely tight. So tight you couldnt compress it. I pumped the clutch a few times and it released. It almost reminds me of a pump in an automatic tranmission. Where it wont engage untill the rpms are elevated, But i really dont have the ***** to test that theory. Are there any die springs in the pressure plates? or just the throwout bearing and the clutch fingers?
Old Oct 12, 2010 | 04:29 AM
GDC-SRT's Avatar
Springs in clutch, and pressure plate.
I will guess you have destroyed one or both.
In any case, while you are in there replace all the parts, including the bearing.
Old Oct 12, 2010 | 04:35 AM
ya for sure. im 27 was a big mopar guy, mainly becuase noone else had them. ran a chevy II with 383. but i love this car. i gave 10k with 73k on it. Any leads on some pretty tough clutches? I really dont want to go back to oem parts. Its amg i know, but would rather spend the extra cash so i can lose my penny loafers and wear my tennis shoes to drive it. lol thanks guys i appreciate it. crossfireforum the best again!! ** one last thing.. are the housing bolts red lock tite in? i thought i read that somewhere.**
Mackel
Oct 16, 2015 09:03 AM
nataliefs
Oct 5, 2015 01:03 PM
Ed Mahoney
Sep 20, 2015 10:35 PM
mecdoux
Sep 20, 2015 12:32 PM
PA/XFIRE
Sep 5, 2015 01:25 PM
