Where to get clutch / flywheel
Old Oct 15, 2010 | 11:36 AM
srt8guy's Avatar
Default Where to get clutch / flywheel
It appears the clutch has failed in my son's Crossfire (04 56k miles). The dealer has outrageous prices.
I can find a few clutch / pressure plate kits on Ebay for 650-750.
I am not having any luck on flywheel (they cost 1100ish).?
Do I also need a throw out bearing (release bearing)
A slave cylinder (mounts internal ) ?
Has anyone replaced their clutch and can you confirm the actual parts list required? I don't trust the dealership at all.
Thanks in advance for your help.
Old Oct 15, 2010 | 11:52 AM
GDC-SRT's Avatar
Default Re: Where to get clutch / flywheel
Parts.com $825.
Disc and pressure plate
I cannot tell if includes flywheel as well.
2005 Chrysler Crossfire Clutch - Parts.com
Old Oct 15, 2010 | 09:16 PM
jdstovallsr's Avatar
clutch kit on ebay buy it noe 672.95
Old Oct 16, 2010 | 09:06 AM
Mike1118's Avatar
What is wrong with the flywheel? Not that I can help, just wonder'n.
Old Oct 16, 2010 | 12:32 PM
Goldwing's Avatar
If you have part numbers, you may want to get quotes from a M-B dealership. Some members have found parts much cheaper without the Chrysler mark-up. I wonder if the flywheel is solid and can be re-surfaced?
Old Oct 18, 2010 | 12:07 PM
I can not offer any assistance, but I would love to know the details of this for the future. Thanks in advance.
Old Oct 18, 2010 | 12:34 PM
srt8guy's Avatar
Flywheel is dual mass, cannot be resurfaced. There was a change in Feb 2004 in the flywheel - You will need your VIN number to get the correct one. For some reason the early one costs more than the later one.
Word to the wise - even if you use the Luk ebay clutch ( 634.00 ) you are looking at 1500 - 1800 for parts assuming you do not need the slave cylinder (reelase bearing) . Centric has it for 82.00 Chrysler has it for 526.00. This is getting the parts yourself, through Chrysler it is about 2500 for parts.
Exeddy also makes a clutch (672).
waldig
Aug 24, 2015 10:40 PM
needfreetime
Aug 1, 2015 07:06 PM
UNDER PSI
Aug 1, 2015 02:11 AM
ricardo 53
Jul 21, 2015 07:49 AM
grphtmtlc11
Jun 22, 2007 06:48 PM
