Just did the Relay Control Module fix
Old Oct 24, 2010 | 12:14 AM
jerry rosewicz's Avatar
Default Just did the Relay Control Module fix
I previously replaced my Crank Position Sensor when my engine died and would not turn-over until it cooled down. Well a few days later the car would not restart at a store stop and I realized the CPS was not the problem!
Decided to do the RCM "Mystery-no- start" fix. Resoldered the three problem joints and nearly messed up the board by melting some plastic near the soldered area! Put the RCM back and reconnected the battery and car started right up. This is good, thought I. But then I see the BAS/ESP light on...oh no!!
Back to the search forum and somone says that light will come on when the battery is disconnected. Turning wheel left full and right full will reset it. Well it did.
Now to drive and see if everything works. Wish me luck and bless this forum and its wonderful members.
Old Oct 24, 2010 | 10:11 AM
Default Re: Just did the Relay Control Module fix
Blees the mighty DJ for the fix....glad she's working for you....
Old Oct 28, 2010 | 09:09 AM
thallc230's Avatar
Hey hey-! thanks a million- I did the exact same identical thing you did, resoldered the joints- well 2 of them, one of the "infamous 3" and and the 2nd one on the board. The initial one that is part of the "infamous 3"( you know- the 3 at the bottom right corner) was what appeard to be JUST starting to go bad, but yes- the BAS ESP light did come on, and reset it like you, and its fine now. I for a couple days thougth as well it was the battery but even at a "cold start" it didnt even go below 9 while starting, so as you- it couldnt be the battery. hope our fix continues to work!
Now to drive and see if everything works. Wish me luck and bless this forum and its wonderful members. [/quote]
KDW4Him
18
Sep 1, 2021 05:47 PM
rperry52@live.com
Feb 14, 2019 12:18 PM
northwest_crossfire
May 30, 2016 05:19 PM
Soma
Dec 14, 2015 07:52 PM
BrenLW
Aug 5, 2015 04:53 AM
