new ABS module
Old Nov 9, 2010 | 08:20 AM
Rick A. Martz's Avatar
Post new ABS module
Need help! i have a 2004 and was told by the dealership that my ABS Module is bad and need a new one for $1,400. can I get one anywhere else? They informed me that it is on National back order. Open for Ideas.
Old Nov 9, 2010 | 08:34 AM
Black03AR's Avatar
Default Re: new ABS module
Is it the ABS Module the ABS Pump or the CAB Module? You can get the ABS pump with the CAB on ebay for between $100 - $200 used. I bought one, had it shipped to the UK and it works just fine. Make sure you buy from someone who offers a warranty.
Regards
AR
Old Nov 9, 2010 | 09:32 AM
Goldwing's Avatar
Do a google search on rebuilt ABS units. There is a company out west that rebuilds for Audis for about $250. Unfortunately I cannot remember their name. I would assume they handle most German cars and we have a Mercedes ABS.
ModuleMaster below is the company name I could not remember. Good job, Bladecutter.
Old Nov 9, 2010 | 12:18 PM
Bladecutter's Avatar
Here is the best company on the net to rebuild your current unit:
ModuleMaster rebuilds ABS modules for as low as $100, 2 day average turn-around, 5 Year Guarantee
Give them a call, and see if they can help you (I bet they will).
BC.
Old Nov 9, 2010 | 03:18 PM
blackcrossfire07's Avatar
That is the problem with stealerships. It is not their fault though.... the parts on this car are marked way up because of Chrylser. Most people here will tell you it is cheaper to just buy straight from Mercedes. Not sure if you can do it with this part. But why pay 1,400 when you can spend a couple hundred!
Old Mar 11, 2014 | 07:10 PM
UCLA's Avatar
I was told my ABS module needed to be replaced, BUT my ABS light did not come one. My CHECK ENGINE light came on. This does not make sense.
Old Mar 11, 2014 | 07:26 PM
What is the code that was set?
You must know what this is to confirm or deny the problem.
Rebuilt or used ABS units are cheaper than new ones.
Old Mar 11, 2014 | 07:43 PM
rmaier's Avatar
The CEL could be on for the ABS as the Body module has some of the communications with the sensors as well but almost always the ABS/ESP light is on for a fault with that system specifically.
Old Mar 11, 2014 | 07:50 PM
UCLA's Avatar
The dealer said when he started my car this morning the check engine light was out, but the following code was in storage:
1352: 1210 and 1212. From this he said it was my ABS module, even though it was Check Engine Light?????
Old Mar 11, 2014 | 11:40 PM
See this thread for details on a 1210 code fault.
1352 seems to be an ignition key fault.
Run the codes on Google and see what you get.
REYMARTZ
22
Aug 7, 2021 12:37 PM
Hoppy
Dec 7, 2018 07:36 AM
northwest_crossfire
May 30, 2016 05:19 PM
Reliableron
Oct 17, 2015 10:19 PM
atdavis2
Sep 21, 2015 01:25 PM
