I trying to find a 74mm TB for my N/A xfire
Old Dec 21, 2010 | 10:48 AM
Charmander's Avatar
Default I trying to find a 74mm TB for my N/A xfire
I have been searching for hours on the forum and found nothing on a MB part number that is a direct bolt-on 74mm TB. Is this true? I read some guys buying from tvt but they no longer in. Anything helps thx.
Old Dec 21, 2010 | 10:55 AM
Beaner's Avatar
Default Re: I trying to find a 74mm TB for my N/A xfire
I will send you the direct bolt on and plug in part number in a second. let me go find it
Old Dec 21, 2010 | 11:12 AM
downwardspiral's Avatar
Let me know if you need help finding one, I found a couple locally last time I looked.
Mercedes Part # A1131410125
Bosch Part # 280750017
Old Dec 21, 2010 | 11:18 AM
Bladecutter's Avatar
Which MB cars is that throttle body from?
BC.
Old Dec 21, 2010 | 01:08 PM
BC.
I think its 02-05 S class, CL and others with the m113 v8.
Old Dec 21, 2010 | 01:47 PM
oyster_gold's Avatar
I assume you would need an aftermarket CAI such as the NeedsWings rig or a stock MB airbox and larger diameter tubing?
Old Dec 21, 2010 | 02:18 PM
deltacrossfirebob's Avatar
i have been thinking of changing mine also.
please post the outcome of your project, ie how difficult to do, performance improvement, ect.
also where you find the part.
thanks
bob
Old Dec 21, 2010 | 03:14 PM
No_Dominion's Avatar
There are currently 5 of them for sale on Ebay.
Old Dec 21, 2010 | 03:29 PM
thanks for the info.
but how wothwhile are they???
performance??
how hard to install??
worth the cost???
thanks again
bob
Old Dec 21, 2010 | 04:00 PM
performance??
worth the cost???
thanks again
bob
I haven't done this mod but from what I've read the TB coupled with a quality CAI (I believe the NeedsWings is the only quality CAI for the x-fire) will give you a nice boost...maybe 5 to 10 hp. (?). TB's are very easy to install. Usually 2 or four bolts depending on the engine.
Old Dec 21, 2010 | 04:28 PM
Beaner's Avatar
Originally Posted by oyster_gold
... TB's are very easy to install. Usually 2 or four bolts depending on the engine.
...4 bolts and 1 plug... here is a pic of the stock TB and the 74mm TB
Old Dec 21, 2010 | 04:31 PM
waldig's Avatar
Talking Re: I trying to find a 74mm TB for my N/A xfire
I got one for my dual system on ebay and they are easy to plug and play with. Ebay wins again, Woody
Old Dec 21, 2010 | 04:33 PM
So can someone confirm...the 74mm does not work with the stock airbox without modification? Would there be any benifit using the 74mm with a stock airbox vs NeedsWings CAI? Does the ECU adapt without error?
Thanks.
Kodebuster
Nov 5, 2020 04:06 PM
Soma
Dec 14, 2015 07:52 PM
ardenian
19
Nov 21, 2015 12:00 PM
velociabstract
15
Sep 7, 2015 03:43 PM
ardenian
Jul 9, 2015 02:08 PM
