Jack location frame pad
Old Jan 2, 2011 | 10:57 PM
cabntmkr's Avatar
Default Jack location frame pad
Has anyone had to replace one of the frame pads for jacking up the Crossfire? I seem to be missing the front one on the passenger side of my '04.
Old Jan 3, 2011 | 08:24 AM
Cody M's Avatar
Default Re: Jack location frame pad
I'm missing one on each side but no worries cause you can still jack up your car at those points and it won't hurt it. In my opinion they are cheap and meant to break off anyways so I wouldn't worry about replacing them.
Old Jan 3, 2011 | 06:51 PM
green-ghost's Avatar
Guys just do a search on them, the forum is full of info. I remember a post not to long ago about this and the MB part # was given etc. good luck, I think theyre like 20 bucks each
Old Jan 3, 2011 | 07:30 PM
TiredRetired's Avatar
Guys, I know this is a really dumb question, but I want to jack the car up and put it on jack stands. If I jack it up at the jack locations, where would I then put the jack stands?
Old Jan 4, 2011 | 02:06 PM
Cody M's Avatar
I put mine right behind the tire then jack up the other end of the car. Just don't go too high with the jack stands.
Old Jan 4, 2011 | 02:13 PM
In the rear, use the rear diff pumpkin, in the front, use either of the control arms. Use a nice rubber pad with either of these locations
Old Jan 4, 2011 | 07:20 PM
You've never called me pumpkin
Old Jan 4, 2011 | 07:43 PM
Thanx. For an owner, I know very little of these cars. I basically bought mine and stuck it in the garage for the duration of the winter. What is the differential pumpkin and what should I be looking for under the car.
Old Jan 4, 2011 | 11:32 PM
I heard that he had, I guess we can squash that rumor.
Old Jan 5, 2011 | 08:07 AM
Thats because you never buy me nuthin nice
The rear differential is the pumpkin shaped device located halfway between your rear wheels on the axle in the center of the car. When you get under the car and look up from the rear, you can not miss it. Just make sure to put blocks in front of the appropriate wheels and use the parking brake when necessary - don't want it starting to roll when half of it is in the air
Hope this helps.
TerryR
Dec 13, 2019 03:27 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Steven 4190
Nov 25, 2015 10:12 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
stlas69
Sep 14, 2015 06:10 PM
