OBD cable?
Old Mar 28, 2011 | 05:57 PM
94Bravada's Avatar
Default OBD cable?
I am getting my ecu tuned from Eurocharged and they sent me the cable for the tune. Since I have the cable already is there any kinda software that I can run on my laptop to monitor my cars levels like rpm, temp, and stuff like that? Eurocharged is out of the shop till monday or I would have asked them. Thanks
Old Mar 28, 2011 | 06:24 PM
bri3d's Avatar
Default Re: OBD cable?
It's a "Galletto" cable, which is basically an FTDI USB<->Serial chip attached to the pins on the OBD-II connector necessary to reprogram German ECUs. No off-the-shelf OBD/CAN software I've found so far seems to support Galletto cables (besides Galletto, of course, which is good only for flashing the ECU) - I'm working on doing some more research in that direction as well, though. I need to figure out how the cable is wired and how Galletto uses the chip (FTDI USB<->serial adapters can also be operated in a "bit bang" mode where the computer tells the chip to turn pins on and off individually instead of as a USB serial port, and I think this might be what Galletto does).
Old Mar 28, 2011 | 06:30 PM
dinasrt's Avatar
A different approach, but here's another way to go. PLX Kiwi - Kiwi Wifi, Kiwi Bluetooth, Kiwi MPG, Kiwi Drive Green OBD 2 Devices*
Old Mar 29, 2011 | 11:21 AM
Jesus_Christler's Avatar
Garmin makes a dongle that works with their Nuvi GPS. Perfect for the plug and play set. Or you can check it with Garmin Mechanic on your Android phone.
REYMARTZ
22
Aug 7, 2021 12:37 PM
rampntlion
21
Feb 11, 2019 08:18 AM
ala_xfire
Sep 28, 2015 05:51 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
skeet370
29
Sep 18, 2015 05:53 AM
