valve cover gasket help
Old Apr 7, 2011 | 06:07 PM
Crossfire725's Avatar
Default valve cover gasket help
i have a leak on my drivers side. but it has 2 gaskets it looks like. one for the valve cover then there is more bolts on top of the valve cover. i have leaks from there as well. is this a normal problem? is that bad? and i was looking on this website and only can find the gasket for the valve cover not the cover on top on the valve cover?
please help and thank you very much.
2004 Chrysler Crossfire ENGINE Engine parts Valve cover FactoryMopar.com
Old Apr 7, 2011 | 06:18 PM
MikeR's Avatar
Default Re: valve cover gasket help
your leak is most likely just on the top breather covers... that is very usual... I just re-did both mine on Tuesday for the second time... the breather cover uses the Ultra Black RTV gasket maker....here is a link for you....
https://www.crossfireforum.org/forum...over-leak.html
Old Apr 7, 2011 | 07:25 PM
NAIN's Avatar
the same happened to me with 30, 000 miles , leaked at the top breather. The Chrysler dealer replaced the whole Part (including the part with the main valve cover) free under my Chrysler extended warranty ($100 copay)
Old Apr 7, 2011 | 11:26 PM
BlazingSaddle's Avatar
Yes, that is one of the common issues with Crossfires. Mine did that at barely 3000 miles. Should be an easy fix.
Good luck.
Old Apr 8, 2011 | 01:14 AM
NeedsWings's Avatar
we can help with...
Mercedes Engine Sealant RTV
and
Mercedes Caulk Gun
or we can do it here...
Teflon Coated Valve Covers 3.2L Mercedes
Old Mar 23, 2015 | 10:43 AM
Cheito's Avatar
Default Re: valve cover gasket help crossfire
[QUOTE=BlazingSaddle;580352]Yes, that is one of the common issues with Crossfires. Mine did that at barely 3000 miles. Should be an easy fix.
Good luck.[cheito
Old Mar 23, 2015 | 11:09 AM
Bill F's Avatar
[QUOTE=Cheito;830856]
Good luck.[cheito
BlazingSaddle's post was 04-07-2011, 10:26 PM
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
Billto
Sep 28, 2015 12:05 PM
Billy22Bob
Sep 26, 2015 10:16 PM
ozkancab
Sep 25, 2015 10:55 AM
