Crankshaft prosition sensor
Old Apr 9, 2011 | 09:29 PM
arejohn's Avatar
Default Crankshaft prosition sensor
I have a new to me 05 with 18k miles. Should I have a BU CPS?
Old Apr 9, 2011 | 09:30 PM
green-ghost's Avatar
Default Re: Crankshaft prosition sensor
yes buy one today
Old Apr 9, 2011 | 10:08 PM
If you are going thru the effort to purchase a crankshaft sensor for a spare, you might as well purchase the camshaft sensor also. Same type sensor, just a different shape.
Old Apr 9, 2011 | 10:41 PM
arejohn's Avatar
Thank you. I will order it with the transmission plug. Anything else I should consider. I have engine and cabin air filters and oil filter. Fixed cup holder. Soon to work on drivers heated seat. Bottom did not work on purchase and back only worked twice.
This thing is a real pleasure to drive.
Old Apr 9, 2011 | 10:48 PM
Be sure your oil filter is the synthetic/fleece and not the run-of-the-mill paper filter. Both my seat heater bottoms don't work, but I hardly drive it in the cold weather so it is not a priority. But if I were to make the repair, I would consider an aftermarket heater, seems the OEM will fail again and again.
Good luck with your new toy! James
Old Apr 9, 2011 | 11:31 PM
arejohn's Avatar
I learned here to get the fleece filter.
I wrote crankshaft when I was thinking camshaft. Which is the one that seems to fail.
It's my wife's toy and I keep telling her it's blocking my Miata. I might have to put Sta-bil in it. The Miata.
Old Apr 10, 2011 | 09:51 AM
MikeR's Avatar
The CRANKshaft position sensor(back of engine, driver side, by bell housing) is the one that seems to fail most.... the camshaft sensor (on the upper front left of engine) will give similar symptoms to the crankshaft sensor when failing...because the ECU looks at them both in relation to timing pulses in order to start the car...
Make sure you keep a 1/4" ratchet, extension and the M8(?) star socket handy also...
Old Apr 10, 2011 | 11:09 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
handy also...
Yes...ETORX Female socket size E8
Old Apr 10, 2011 | 12:16 PM
arejohn's Avatar
OK. I know what I need so I look for CrossfireForum advertisers and sponsors. Who are they? The retailers that offer discounts. I like to spend my time and money within the group.
Old Apr 10, 2011 | 12:27 PM
arejohn's Avatar
I had a V8 and found the vendor section.
Old Apr 10, 2011 | 01:19 PM
There is nothing wrong with the paper filters, I just would not run them for too many miles. The 2004's came with paper filters, and probably other years as well. Cars had paper filters for years with no problems, so no panic needed on that score.
The fleece filters are mandatory for the extended oil changes though.
Old Apr 10, 2011 | 07:41 PM
MikeR's Avatar
Yeah, I get M's and E's mixed up..... if I could just remember that M is male and E is ewe, I would be okay.. but then I would have to remember what is on the car too.....
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
caseydeankopp
Sep 13, 2015 07:25 PM
bobbie
Sep 12, 2015 12:49 PM
2004_
Sep 4, 2015 01:39 PM
