245/35R20 fit in the front?
Old Apr 27, 2011 | 04:56 AM
Crossfire725's Avatar
Default 245/35R20 fit in the front?
245 is the width and it says 245 = 8.5 inches. So I'm guesssing they would fit? Off set was 35 I think I will double check. Thanks
Yeah its 35 offset. 245/35R20 in the front and the rears are 255/35R20
Two different web sites say they will fit. Just can't always trust them.
Thank you
Old Apr 27, 2011 | 07:38 AM
Default Re: 245/35R20 fit in the front?
IMO they will NOT fit. Even moreso if you are doing ANY lowering.
I had a 225/30-20 on the front with OEM suspension and needed 5mm spacers with a 35 offset.
Old Apr 27, 2011 | 08:09 AM
U shure. I was told that they may fit. I kno the 245 width will fit cause there 8.5 inches wide. Witch is fine. But the 40 height is the only iffy thing.
Old Apr 27, 2011 | 09:34 AM
Will 225/30R20 fitt it in the front!!
Old Apr 27, 2011 | 10:22 AM
MMZ_TimeLord's Avatar
Give this spreadsheet a try. (Linked from the Crossfire Document collection)
I have 245/35R18's on the front. With a sidewall profile of 35 on a 20", you are going to be WAY too tall. Just over 1.6" overall wheel height, raising your vehicle by over 3/4". A 245/30R20 will be about 3/4 of an inch taller overall than stock height, raising your vehicle in the front by about 3/8". A 245/25R20 would be 1/4 inch shorter overall, lowering your vehicle by 1/8".
The offset calculations are in the spreadsheet. I have no rubbing at all with my 245/35R18 tires on the rims listed in the spreadsheet. No spacers in the front and 32mm offset.
Also, keep in mind your rim width vs. the tire width. There is a maximum tire width you can put on a rim before it will break the bead.
Hope that helps.
Old Apr 27, 2011 | 10:25 AM
About 225/30R20
maxcichon
May 14, 2019 07:30 PM
velociabstract
28
Oct 28, 2015 12:46 PM
toob
Aug 19, 2015 07:31 AM
waldig
Aug 14, 2015 01:02 PM
ardenian
Jul 27, 2015 04:41 PM
