Blinking fuel light & P0455 code
Old May 18, 2011 | 02:49 PM
jackei's Avatar
Default Blinking fuel light & P0455 code
Hello,
Does anyone had the blinking fuel light and the P0455 Evaporative Emission Control System Leak Detected (gross leak) code?
I searched the forum, and found some members had such problems. However, all thread were at least 3 years old, and there were no conclusion of the cause or how to fix. Some suggested (and replaced) the fuel cap, while some was the fuel sensor.
I'm wondering if there are any updates.
Thanks!
Old May 18, 2011 | 08:56 PM
rongarant's Avatar
Default Re: Blinking fuel light & P0455 code
I had the same thing happen the other day. I still had half a tank of gas but I filled it up and the blinking light went out and hasn't came back on.
Old May 18, 2011 | 10:09 PM
Try this:
OBD-II Trouble Code: P0455 Evaporative Emission Control System Leak Detected (no purge flow or large leak)
Old May 18, 2011 | 10:24 PM
The main cause is usually the gas cap, loose or faulty. The second most thing I have found are vacuum lines split open at fittings, Tees, etc...
James
Old May 18, 2011 | 10:43 PM
robby363's Avatar
When you fill the tank do you stop when the pump clicks off or do you try to squeeze more in to round it off to an even dollar amount? If you do that it can cause the fuel light to blink. Over filling it can cause fuel to get in the evaporative emissions system. I found this out when I first bought my car. If I squeezed in a little more after the pump first stopped. The light would come on after it got to about a 1/2 tank. It hasn't blinked sense I stopped trying to squeeze a little more in.
Old May 19, 2011 | 11:01 AM
jackei's Avatar
I guess changing the gas cap is my next step. I found this on amazon ( Amazon.com: Stant 10843 Fuel Cap: Automotive ) Does anyone knows if I got the correct one? Thanks.
Same thing happened on me. First the blinking light once a few weeks, then once a few days, then the P0455 code. Now both blinking light and P0455(after I reset) came on everyday.
The main cause is usually the gas cap, loose or faulty. The second most thing I have found are vacuum lines split open at fittings, Tees, etc... James
Where are the vacuum lines located? or do I just inspect all the black rubber hose under the hood?
No, I stop at the clicks, although I might have did it a long time ago.
Old May 19, 2011 | 03:00 PM
Read the Repair Manual, section 9, page 399 onward. There is no point in guessing.
Old Apr 11, 2017 | 02:50 PM
asantillan's Avatar
so I am trying to make sense of all this, I replaced has cap not sure if this is whats needed next, cant find anything on the service catalogue
2004-2008 Chrysler Crossfire Vapor Canister Purge Solenoid - Engine Electrical - Standard Motor Products 04-08 Crossfire Vapor Canister Purge Solenoid - 17854-05224167 - PartsGeek
Old Apr 11, 2017 | 03:37 PM
This thread is six years old, search for a later thread. Purge valve system was the fault last time.
jgreen
106
Sep 18, 2017 11:46 PM
northwest_crossfire
May 30, 2016 05:19 PM
axnguyen
Jul 21, 2015 11:41 AM
bdh
Jul 9, 2015 09:40 AM
Blackout317
Jul 7, 2015 08:38 PM
