Help!! Clutch won't engage, can't shift gears
Old Jun 23, 2011 | 12:07 AM
buniqueXF's Avatar
Default Help!! Clutch won't engage, can't shift gears
So to try and make a long story short......i'm driving up rt 53 in joliet tonight, screwin around with a kid in a focus wound it up to about 100 and then put the clutch in and popped it out of 5th into neutral to coast for a while until i had to make a right turn. When my turn came, i still had the clutch in, i went to put in in 2nd and no luck...it wouldn't go, tried to put alittle pressure on it and it just grinded alittle so i stopped. Pulled the car over and realized that the clutch was still deptressed to the floor and the whole car was shaking and a slight clicking sound was coming from underneath. I lifted the clutch back up with my toe and tried to depress it again and it was very dificult to press and the car still wouldn't go into gear. So i shut it down and called the tow truck. 3 hours later the truck shows up and drops me and the car off at the mechanic........Anyone have any ideas what this might be? I tried searching but nothing seemed to be quite what i'm experiencing. Its a 2004 Limited with 65000 miles on it, 6 speed and i tend to drive in a spirited fashion...... Thanks for the help.
Old Jun 23, 2011 | 10:05 AM
user 8202's Avatar
Banned
Default Re: Help!! Clutch won't engage, can't shift gears
It appears you have had a catastrophic component failure. Taking a closer look at the clutch assembly will reveal the damage.
Why is it called a parachute?
para = parabolic, the shape of the chute?
Old Jun 23, 2011 | 04:24 PM
buniqueXF's Avatar
Anybody else have any useful ideas of what coulda went wrong? I coulda told you that there was a component failure
Old Jun 23, 2011 | 04:33 PM
dtinker's Avatar
Any chance of a hydralic slave cyc .failure or a hose leak??
Old Jun 23, 2011 | 04:34 PM
Use search and use 'clutch failure' we had a similar request last month and the guy said he'd tell what happened, he didn't and we are still waiting.
Old Jun 23, 2011 | 04:39 PM
I hate to say it, but I have a feeling this will be MANY hundreds of dollars to fix.
PLEASE get back to us when you have it fixed and let us know!
Old Jun 23, 2011 | 08:06 PM
after you reached 100 mph, you pushed in on the clutch to shift to neutral...to coast awhile...
did you let the clutch back out while coasting?
Either way, it isn't good to just let everything free wheel at those speeds
Could be a lot of things...pressure plate, linkage, bearing....I have never seen a clutch apart on one of these babies...keep the clutch engauged while playing...
Old Jun 23, 2011 | 10:18 PM
buniqueXF's Avatar
Well the car is still sitting in the same spot that the tow driver left it last night, so aparantly my mechanic didn't have time to look at yet today...... I wasn't sure where the hydrolic resevoir was to check it, but when i looked under the car after it had been sititng for 24 hours there wasn't anything that appeared to be leaking. I've got a feeling to that this is going to be an expensive one also, oh well the car is worth it. I'll def keep everyone updated as to what it turns out to be Thanks all for the help
Old Jul 2, 2011 | 01:59 AM
buniqueXF's Avatar
So heres the story......basically the clutch exploded, my mechanic said there was shrapnel everywhere, it also damaged the flywheel so that had to b replaced too.....so anyway just shy of 2700 dollars later my baby is back on the road. dfinately a difference in the clutch i guess it was more worn than i thought
Old Jul 2, 2011 | 05:22 AM
phyrephlyte's Avatar
Wow; considering that many people wait months for a little plastic part for repair, I am impressed you had such swift results with such a "catastrophic" situation. (and most amazing , you didn't ***** about the price)
Good luck, and maybe be a little less spirited, you car is up in dog/car years.
PP
Good luck, and maybe be a little less spirited, your car is up in dog/car years.
PP
Old Jul 2, 2011 | 06:16 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
$2700 for a clutch and flywheel is rediculous. Should'nt cost more than $700 incl. clutch, release bearing and flywheel plus install of $500-$700.
Old Jul 2, 2011 | 07:01 AM
True, but you don't how much damage was done inside the bellhousing. If they had more hours in cleaning up the mess of a 100 mph shrapnel explosion, plus, a flywheel which usually isn't needed, it would cost more. Even so, they got you for a cool grand kid...no more coasting....as the clutch probably already had a problem, broken spring, whatever, and with it freewheeling, it probably came apart, rattling around in there, and once you reingaged the clutch all hell broke loose...who knows, but keep the clutch engaged while coasting, just kick it out of gear....now go make us proud...
Old May 11, 2013 | 08:43 AM
topgun69's Avatar
You obviously have not one clue about what you just said about freewheeling at 100 miles and hr.
Old May 11, 2013 | 01:20 PM
+fireamx's Avatar
I always thought keeping the clutch pedal depressed while coasting prematurely wears out the "throw-out bearing".
Heck, I even put my car into neautral and take my foot off the clutch when I'm sitting at a traffic light.
Old May 11, 2013 | 03:09 PM
Indelibility's Avatar
I'm going to have to disagree. A clutch kit alone will cost around $700, most flywheels are $1,200. Then factor in the install time, sounds about right to me.
Unless of course you can find a clutch kit and flywheel for $700. I'd buy one now and keep in for later.
Old May 15, 2013 | 10:07 PM
Nordschleife's Avatar
Some cars you can replace the flex plate and modular clutch with an aftermarket kit where the flywheel is the rear pressure plate as well. It saves a bit of weight and resists warping from heat soak better. ACT makes a few models of such, but I don't know if they have any compatible part numbers for our drivelines.
OP, consider yourself lucky that the clutch didn't grenade the entire bell housing. I'd imagine it would have been much more painful having to replace a transmission case as well
Old May 15, 2013 | 11:20 PM
Selbyl's Avatar
I would request to see the Flywheel, it could possibly just need resurfacing or something like that. But you must be pretty hard on your car I'm at 96K on the original clutch and I take mine out to the drag strip about once a month.
Old May 15, 2013 | 11:33 PM
MoparFreak69's Avatar
Notice the dates.... 2 years ago.....
crossfireusa
Oct 28, 2015 12:03 AM
Mackel
Oct 16, 2015 09:03 AM
jimf
Oct 10, 2015 10:22 AM
rfourt
Sep 25, 2015 01:38 PM
mecdoux
Sep 20, 2015 12:32 PM
