Auto Transmission Fluid replacement intervals
Old Jun 27, 2011 | 04:21 AM
Berkshire_Crossfire's Avatar
Default Auto Transmission Fluid replacement intervals
Hi,
Can anyone tell me what the recommended replacement intervals are for the auto transmission fluid? Also what is the recommended type of fluid to use if I am going to do this myself.
Many thanks,
BC
Old Jun 27, 2011 | 05:46 AM
32krazy!'s Avatar
Default Re: Auto Transmission Fluid replacement intervals
40k is what m/b recommends. either use sprinter fluid from chrysler or the oem m/b fluid. either way it costs a bit. around 20$ per qt
Old Jun 27, 2011 | 10:07 AM
At 50k I plan to drop the pan and change the filter and fluid. After that, I plan just to drain the fluid from the drain plug and refill at about every 20k- kinda freshen it up abit from time to time.
My experience is that it is most important to get that filter changed out one time due to break-in material caught in the filter. After that, keeping the fluid fresh will work just fine.
James
Old Jun 27, 2011 | 11:45 AM
Mimi05SRT6's Avatar
James
Excellent advice!
Old Jun 27, 2011 | 12:36 PM
tighed1's Avatar
Anyone have a lead on where to buy the fluid cheaper? On line perhaps?
Part number? (at work can't search)
Old Jun 27, 2011 | 12:39 PM
Service schedule for Trans fluid is 100K miles or 5 years.
Old Jun 27, 2011 | 03:25 PM
stlas69's Avatar
Automatic Transmission
The fluid in the automatic transmission should be
changed at 80,000 miles (129,000 km), along with the
transmission fluid filter. After that, the transmission fluid
is filled for life.
Old Jun 28, 2011 | 08:39 PM
rekcah's Avatar
The correct MOPAR number at the dealer is 05127382AB. I believe $25ish/qt. not sure on price. When I bought a qt at the dealership they gave me the cheap/wrong $8 ATF fluid, when I went back they just exchanged it to the right fluid at no extra charge, so I got a deal there.
Just make sure it says, "CROSSFIRE / SPRINTER" on the bottle.
Old Jun 28, 2011 | 11:04 PM
maxime75us's Avatar
To All,
The cheapest filter is at Autozone..
AboutATF Fluid, PM me I will send you a quote for Amsoil ATF, must cheaper than $20 bucks.
Most of the time NO TAX.
My best
Max
Old Jul 16, 2011 | 06:36 PM
Mimi05SRT6's Avatar
I would think a Full synthetic ATF would be best for our cars, just like using synthetics in the crankcase. Not sure if the Mopar oil is synthetic or not. You think it would be for how much they charge us for it.
Old Jul 16, 2011 | 07:14 PM
waldig's Avatar
Talking Re: Auto Transmission Fluid replacement intervals
i used the mopar +4 fluid wihch seems to have the correct specs. It is less than $20. Woody
Old Jul 21, 2011 | 12:51 AM
Mimi05SRT6's Avatar
Supposedly the Mopar ATF+4 is nearly the same or compatible with the MB fluid. Did quite a few searches on it and I guess that is why the Chrysler stealerships are putting it in our crossfires. That is what they put in mine. So I guess if it's ok in your car Woody, it's ok in mine too.
An interesting read on MBWorld about this fluid...
http://mbworld.org/forums/e-class-w2...r-atf-4-a.html
Old Jul 21, 2011 | 04:43 PM
arejohn's Avatar
236.14 approved fulids:
MB 236.14 - Automatic transmission fluids (ATF, Specification 236.14) - Mercedes-Benz Specifications for Operating Fluids
Old Jul 21, 2011 | 04:58 PM
Thirteendog's Avatar
Some dealers have it by the gallons. I believe I paid $25 for a gallon when we did mine.
Old Jul 22, 2011 | 12:24 AM
DavidOv54367's Avatar
is filled for life.
1+
12345678
Crossfireconv08
Jul 30, 2015 12:11 PM
Jul 29, 2015 06:13 PM
chturner
Jul 24, 2015 04:47 PM
Romio
Jul 24, 2015 07:03 AM
