Check Engine Light
Hey guys!
Had something weird happen to me over the last couple of weeks. Every once in a while, I start the car, then stalling but eventually it will turn on and THEN the check engine light stays on. It stays on for a few hours and the next day its off again. What does this point to? The stalling at engine star is what concerns me. Once again, this doesn't happen with every start but when it happens the warning light pops up. I got a 2004 Limited N/A with 54,000 Miles on it.
Thanks for any hints of what might cause this (Spark plugs, etc.)
Thanks,
Nick
Thanks,
Nick
Originally Posted by nickwe21
Hey guys!
Thanks,
Nick
Thanks,
Nick
MAF sensor is dirty
Second guess
O2 sensor.
Third guess is
fuel pump failure.
First guess
MAF sensor is dirty
Second guess
O2 sensor.
Third guess is
fuel pump failure.
MAF sensor is dirty
Second guess
O2 sensor.
Third guess is
fuel pump failure.
Silly me, I was going to ask what the CEL code was LOL
Wow, pretty detailed diagnosis for as little info as he posted. You must be getting better with age, Franc
Please note I did say the magic word..."Guess"
True failure is the inability to recognize your mistakes when you repeat them.
Just got back from Autozone for read outs.
Here's what they found:
1. Code: P0335 Crankshaft Position Sensor A Circuit Malfunction
2. Code: P0410 Secondary Air Injection System Pending
Unless you had one in your pocket and can do it yourself.
Another member provided this information before.
Xfire Service_Crankshaft Position Sensor Replace.pdf
so what do I need to do? My neighbor is a mechanic he will be able to help me out, but he's gone for the weekend. What's the course of action here?
https://www.crossfireforum.org/forum/technical-modifications/16885-crankshaft-position-sensor.html#post143294
As for the P0410 try this thread, as it says it may be just a poor ground. Burnt contacts in the RCM may be the culprit as well.
https://www.crossfireforum.org/forum...-solution.html
There is no damage being done it appears so you could just live with the light. However it probably would not pass any State test with the light on.
If that does not anaswer your question try using search 'P0410', lots of answers.
Lotsa trips back to the parts store and late nights reading posts on this forum. Some of you guys actually do know your ****.
A wrong guess counts as a swing and a miss here.
Good job this is not baseball or you would be "OUT!" on three strikes.
Anyone with absolutely no knowledge of cars can suggest taking it over to Auto Zone. He asked what those symptoms might mean. CPS generaly doesn't let the E light go off and most often shuts the car down. As for the symptoms, I have experienced them and those where the components involved.
What's your beef? Or more to my puzzlement, what is the point of your beef?
Just went ahead and ordered the part. Found it online - original Mercedes part made by Bosch in Germany. Looked over the pictures of the installation and shouldn't be a problem to do. I will do it under supervision of my friend the mechanic
As for the post above, I think it's all just fun and games. Any tip here is greatly appreciated and I really like how people try to come up with solutions for the problem rather than saying "go to the dealership, they will figure it out for you (and also figure out how to empty your pockets)". So thanks to ya'll for contributing to this discussion.
Given the original info, those were good guesses. And I admitted they were so.
So lighten up when your on other forums, no vitriolic posts here, well not lately anyway.
I will not joke with you again, how's that?
Sorry if I seem too sensitve to your snarky reponse Dave.
Boiler up said essentially the same thing but somehow with a little more tack. His joke I got.
[quote=Franc Rauscher]Sorry if I seem too sensitve to your snarky reponse Dave.
Boiler up said essentially the same thing but somehow with a little more tack. His joke I got.[/quote
I have lots of tack, you just missed the point.
[quote=onehundred80]
Enough ping pong old man. I yield.
Besides nobody cares....
Neither you no I helped a twit. DJ got him squarded away.
Nickwe21 got his crossie going again. All that mattered
True failure is the inability to recognize your mistakes when you repeat them .
