Bas/esp?
Old Oct 4, 2011 | 05:26 PM
XfireDvr's Avatar
Default Bas/esp?
My BAS/ESP light comes on every so often. Seems like its when I turn my stereo systems up it does so. I have 2 12" Kicker CVR, AMP and a capacitor. Why does this light keep coming on but goes off if I turn my car off then back on?
Old Oct 4, 2011 | 05:36 PM
Default Re: Bas/esp?
You need to have a volt meter reading of the battery circuit when you have the system cranked up. It may be taking the electrical system down low enough to effect the voltage going to the BAS/ESP systems, causing the light to come on.
Try to monitor the car voltage when cranked. You can buy a digital meter to plug into your cig lighter to monitor voltage.
James
PS My son had some similar issues with his Blazer. He had to buy a high output alternator to correct the problem. He also installed a digital read out volt meter on the dash so he knew how loud he could go before it would effect his charging system.
Old Oct 4, 2011 | 05:41 PM
you can put the car in the on/run position, then, crank the wheel all the way to the right stop, then all the way to the left stop, then back to center... This should reset it...but there is a sensor, that could be going bad as well. The Angle Sensor, or something like that...James may be correct as well. The car is sensitive to voltage spikes...
Old Oct 4, 2011 | 09:17 PM
XfireDvr's Avatar
What if I get a Redtop battery?
Old Oct 4, 2011 | 09:36 PM
Cedar11's Avatar
Whats that AMP rated at? And how high of a load do you have it wired up to? Depending on how big of a load that amp is running at, that capacitor might be hurting more than helping. Its always a better idea to upgrade "the big 3"/battery/alternator before getting a capacitor. Depending on your amp, my advice to you would be to ditch the capacitor, upgrade your "big 3" and then look at a battery like the RedTop you mentioned, or even better the YellowTop.
Old Oct 4, 2011 | 09:45 PM
If that system made you blind instead of deaf you'd wouldn't notice.
Old Oct 4, 2011 | 09:48 PM
XfireDvr's Avatar
What exactly is the "Big 3"?
Old Oct 4, 2011 | 10:23 PM
It may be before your time but it meant GM, Chrysler and Ford. But sometimes now its three wires on your car.
Kinda sad really.
KDW4Him
21
May 13, 2016 09:47 PM
xfClifford
27
Nov 10, 2015 10:08 PM
Blackout317
Jul 7, 2015 08:38 PM
millerzrule22
Apr 11, 2015 10:15 PM
rfors777
Sep 1, 2010 04:54 PM
