ignition
Old Oct 26, 2011 | 05:41 PM
rigamo's Avatar
Cool ignition
i have a 04 and the key is stuck in the ignition. The car starts fine just cant get key out. Any suggestions?
Old Oct 26, 2011 | 05:45 PM
Default Re: ignition
search for 'sticky ignition key'
( https://www.crossfireforum.org/forum...y+ignition+key )
Old Oct 29, 2011 | 11:30 AM
rigamo's Avatar
i installed the new ignition switch and the same problem happened. As soon as i disconnected the parking interlock cable the key came right out. What i need to know is where does that cable go and what does it attach to and do i need this? car runs , starts, and drives ok and no lights on the dash.
Old Oct 29, 2011 | 03:11 PM
The purpose is to prevent you from removing the key and getting out of the car WITHOUT it being in PARK.
If you ALWAYS set the emergency brake, then you could do without it, but there is always that one time you will be in a hurry, park on a hill and forget.
However, there is always a ready market here for used parts from totaled cars, so go ahead
Old Oct 29, 2011 | 03:30 PM
rigamo's Avatar
ha ha you still didnt answer my question
Old Oct 29, 2011 | 03:33 PM
The cable goes to the transmission selector assembly.
Old Oct 29, 2011 | 03:36 PM
rigamo's Avatar
is there a particular part that i can replace to fix this problem? and by the way thanks for the sensible answer
Old Oct 29, 2011 | 03:51 PM
I thought this pin was removed entirely in the mod so as never to be a problem again.
That's what I'll do. The steering wheel will not lock up though if you do the mod 100%, I will read it again to be sure of my facts though.
Old Oct 29, 2011 | 04:11 PM
rigamo's Avatar
[quote=onehundred80]I thought this pin was removed entirely in the mod so as never to be a problem again.
That's what I'll do. The steering wheel will not lock up though if you do the mod 100%, I will read it again to be sure of my facts though.[/quote
unless there is different post for " key stuck in ignition" ? because the key turned and started the car?????]
Old Oct 29, 2011 | 05:53 PM
OK, I'm not sure why you purchased the new ignition switch. This is not altered by the Sticky Key fix. The cable attached to the ignition switch goes to the gear selector assembly, this cable is attached to it and is rotated 90 degrees to release it. I would look at that end and see if all is well. The instructions to remove the housing is in the Repair Manual, in the Steering section #19 page 19. in the 2004 Repair Manual.
Old Oct 29, 2011 | 06:46 PM
turbomar's Avatar
The pin removal will delete the steering wheel locking feature only. When you cant remove the key, a shifter/lock cyl. cable adjustment is required. Not sure but I think it's done @ the gear selector end.
Old Oct 30, 2011 | 10:15 AM
rigamo's Avatar
thanks for the info. i will ask you and 180 for info. next time i need some answers
Old Oct 30, 2011 | 10:50 AM
I don't blame you, and I apologize for being somewhat flippant. Truth is, I didn't read the entire question, just the part about "do I need it" stuck in my head. I realize the frustration you must be facing, and am sorry I was of no help.
BTW, you can find instructions on replacing the shift interlock cable in the Service manual in section 19-19 :
http://www.gleamingedge.com/mirrors/...e%20Manual.pdf
Old Oct 30, 2011 | 11:11 AM
rigamo's Avatar
apology accepted.
Old Oct 30, 2011 | 11:21 AM
The cable part number is 05096646AA, but I had absolutely NO luck googling it.
tcar32909
Aug 1, 2024 02:41 PM
fastfred
Nov 5, 2018 09:47 AM
jhansen
21
Feb 15, 2017 04:26 PM
fastfred
Sep 24, 2015 03:05 PM
BEATv1
Sep 10, 2015 12:58 PM
