Dipstick "O Ring? I goofed ... wrong info
Old Nov 1, 2011 | 01:52 PM
IBLUBYU's Avatar
Default Dipstick "O Ring? I goofed ... wrong info
This is my BAD, and I'm sorry. I posted previously that when visiting with Rudy, I thought I saw him use the extra "O" ring that comes with the Mann and K&N oil filters, and put it on the dipstick. Not true!!! I talked with Rudy today at Speedriven (they're doing some maintenance on my coupe), and he said that the "O" ring he puts on the dipstick is the old smaller one off the oil filter housing. Not the extra medium ring. That indeed is just "extra". Evidently used on other newer cars with longer housings. So I say ..."my bad"
Old Nov 1, 2011 | 03:16 PM
MikeR's Avatar
Default Re: Dipstick "O Ring? I goofed .. wrong info
I have been using the small one off the filter post for the last couple of oil changes..... I am only a couple hundred miles from doing it again.....
Old Nov 1, 2011 | 08:28 PM
Larry Hitze's Avatar
It happens, at least the correct info is out there!
Old Jan 23, 2013 | 03:44 PM
aschrager's Avatar
Default Re: Dipstick "O Ring? I goofed ... wrong info
just found out where the 5th O ring goes. The oil filter cap unscrews from the shaft that the filter goes on. If you unscrew it you will see it. I was also told that if the shaft isn't loose. Leave it alone. Don't replace the O ring if the shaft isn't loose.
Old Jan 23, 2013 | 04:02 PM
IBLUBYU's Avatar
AND THE BEAT GOES ON ...... we never stop learning. Thanks Alan
Old Jan 23, 2013 | 04:27 PM
waldig's Avatar
Talking Re: Dipstick "O Ring? I goofed ... wrong info
This is old news now but this was the first write up on this 'upgrade'. Enjoy, Woody
https://www.crossfireforum.org/forum...at-waldig.html
Old Jan 23, 2013 | 04:33 PM
boostmonkey's Avatar
BLESS YOU!!! I have been wondering that for years!
Old Jan 23, 2013 | 04:34 PM
Originally Posted by IBLUBYU
[FONT=Comic Sans MS I talked with Rudy today at Speedriven (they're doing some maintenance on my coupe), and he said that the "O" ring he puts on the dipstick is the old smaller one off the oil filter housing. [/FONT]
This is a good trick to know! Thanks!
Old Jan 23, 2013 | 04:58 PM
sk8erjosh09's Avatar
That is awesome!!!! Im getting close to changing the oil anyway. Ill prolly replace that sucker for S's & G's... Thanks for the heads up!
syfi
Mar 28, 2026 04:14 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
thatcham
Oct 5, 2015 02:41 PM
4drturbo
Oct 2, 2015 12:58 PM
