Windscreen wiper sensor keeps turn on
Old Nov 14, 2011 | 11:51 AM
aviram's Avatar
Default Windscreen wiper sensor keeps turn on
Hello i have xfire 07 and i have Windscreen wiper sensor that it keeps turn on even there's water for the windscreen.
someone knows how to fix this problem?
Thanks
Old Nov 14, 2011 | 04:06 PM
kurtisberry's Avatar
Default Re: Windscreen wiper sensor keeps turn on
You're low on washer fluid?
Old Nov 14, 2011 | 04:47 PM
Ah, now I see the problem.
Maybe the windshield washer fluid sensor is broken, the float is jambed or the connector is loose.
Old Nov 15, 2011 | 03:27 AM
aviram's Avatar
yes i think this is the problem, How can i fix this problem?
Thanks
Old Nov 15, 2011 | 09:38 AM
Thanks
This is how to get to the windshield washer bottle.
Take it out and look at the connections and the level switch.
https://www.crossfireforum.org/forum...tml#post420447
Old Feb 24, 2012 | 06:05 PM
marlam's Avatar
I have the same problem with the washer fluid warning light coming on intermittently, even though the reservoir is full. Did you solve the problem by following onehundred80’s suggestion, or by another approach?
Old Feb 24, 2012 | 06:23 PM
Talk about coincidences, I answered this post and one week later I picked up the SRT and it had the exact same problem.
I took out the tank, cleaned out some slime that was in the bottle and on the sensor. I'm hoping the slime was jamming the float a little and causing it to flicker when the bottle was at the level just above the point where the light would come on and stay on. There is a delay built in to stop the light flickering if the float is bobbing up and down due to the cars motion.
After using some fluid the light stayed on permanently. I hope it is solved as it's a pain to remove the tank.
Edit, May 5 2012
Fix worked OK as light has not come on again.
Old Feb 24, 2012 | 06:28 PM
I had a problem with my 2002 camaro light flickering all the time. I used a little dish detergent in the bottle and used high pressure water squirted into the bottle. It of course overflowed all foaming but you should have seen all the brown gunk it took out. I did that twice more, and that light never came on again unless it was actually low. Maybe a heavy duty flush cleaning would help? I don't know but could it hurt?
Old Feb 26, 2012 | 11:00 AM
marlam's Avatar
Thanks for the comments. A couple of weeks ago I drained the reservoir completely and then filled it up again and the light went off. But It was back on again last week, even when full. Next time I am out I will run it down again and then try blasting it with a bit of pressure, but I suspect that there may be a problem with the sensor (electrics) rather than the float. Thanks.
Old Feb 26, 2012 | 11:24 AM
You will have to take the tank out to clean it as the filling tube is only about 1/2" in diameter and goes through two 90° bends before you reach the tank.
I'm hoping my problem is solved but I have my doubts.
Tank capacity is 7 liters (7.4 qt) so draining it would not be fun without the tank on the floor.
When you take out the tank remember how you did it as putting it back can be a real pain if the fender liner is not completely removed, completely removing the liner is a big pain as well.
Removing a full tank would be a real pain in the tail bone.
Old Feb 26, 2012 | 11:41 AM
And when you get the level sensor out and clean it, don't do something stupid like I did and put it back in upside down. That ensures that the indicator light is on until the level drops below the sensor, not what you want.
The little flat part on the sensor housing goes TOWARD the tank so that the foam flotey thing will float UP when fluid is above the sensor level.
Old Feb 26, 2012 | 11:56 AM
I did not think the round side of the sensor would fit against the flat on the tank.
How big was the hammer you used to make it fit. LOL
I think they have to put the sensor in upside down in Australia.
Old Feb 26, 2012 | 12:03 PM
turbomar's Avatar
te hee. Dont the toilets swerl clockwise in Australia as well?
Old Feb 26, 2012 | 12:11 PM
It fits just fine with the flat side out. ( And the connector catch is on top like it should be when it is upside down )
Old Feb 27, 2012 | 03:24 AM
marlam's Avatar
Sounds like there is a lot of potential for a non mechanically minded person like me to go wrong! The car will be due for an MOT and service in April, so I may get my service center to have a go then. They look after 4 Crossfires, so they know the car.
hecti
Oct 7, 2015 06:11 PM
glover
U.K.
Aug 24, 2015 08:03 AM
glover
Aug 23, 2015 05:07 PM
toob
Aug 19, 2015 07:31 AM
Ricsoc67
Aug 6, 2015 07:56 AM
