Crank shaft Sensor affect alternator
Old Nov 19, 2011 | 11:07 AM
DieselBear's Avatar
Question Crank shaft Sensor affect alternator
I recently started having problems with the electricity output within my dashboard and other components, one day while I was driving on the highway the car decided to just die in the middle road (no answers).
The car was towed to a nearby mechanic who stated that the crankshaft sensor required to be replaced (which the car was fixed and was back on the road), within the 2nd week the battery signal started flashing so I decided to buy a new battery. Within 2 weeks of the new batter the car died just like the 1st time while driving on the highway. I took it back to the same dealer informing them the car experienced the same problems, after a few diagnoses and ($180.00) they told that I needed a new alternator (which I am being charged for $1600.00 parts + labor).
I am asking for some guidance within this forum. Question: Could the crankshaft sensor affect the alternator? Or this one of those components that when changed the alternator must be changed as well?
I am a true crossfire fan and this is the only place where I feel I will get some straight answers... I will truly appreciate your feed back!
Sincerely, DieselBear (bear community)
Old Nov 19, 2011 | 11:13 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Crank shaft Sensor affect alternator
I would suggest that you review the RCM fix (Relay Control Module) . Simple solder repair to a factory problem.
https://www.crossfireforum.org/forum...-no-start.html
Old Nov 19, 2011 | 11:27 AM
DieselBear's Avatar
Thank you I will look into this. Any other suggestions? Cause am being faced to just purchase a new alternator, but I feel the alternator went bad due the crankshaft sensor.
Old Nov 19, 2011 | 11:28 AM
Alternator??
How many miles on the car?
Old Nov 19, 2011 | 11:43 AM
DieselBear's Avatar
90,000 (miles)
Old Nov 19, 2011 | 11:48 AM
Doubtful it was the crankshaft sensor - It has nothing to do with electrical/charging system in the car. But if your old battery was defective, it could have put extra strain on the alt and took some time to finally give out.
James
Could be alternator but I would get them to hold off and perform the RCM fix first and see if this corrects the problem. Hopefully save some $$.
I would never pay that kind of $$ for an Alt replacement.
Good luck.
Old Nov 19, 2011 | 12:36 PM
$1200.00 for an alternator is ridiculous. Check all the part's places 1st. Autozone, Directparts, etc... Perform the RCM fix, trace all your battery cables to their source, to make sure of tight non corroded connections...
blackpepper
Oct 4, 2017 06:09 AM
RED DOG
Oct 5, 2015 07:59 PM
Oct 1, 2015 01:42 AM
JEFASOLD
Sep 28, 2015 12:10 PM
Sep 25, 2015 02:16 AM
