Minor problems
Old Jan 27, 2012 | 04:12 PM
dskul1's Avatar
Default Minor problems
Well, tomorrow I will have had my car one week. I have put a little over 200 miles on it. I have one problem that I knew about when I purchased the car and one unforseen problem. The first problem is that the electric door locks do not work. When I bought the car I thought it was just dead batteries in the key fob. New batteries and the locks still will not work. the switch in the car does not unlock/lock the car either. So I guess it is a switch or ??. I don't even know where to start to find the problem since I know nothing about how this system is put together. Suggestions? The other problem is the "standing" lights, both left and right will not turn off. Right now I have to unhook the battery or take out fuses to keep the battery from dying. I need to get a new switch to fix this I assume. Is there any xfire fix-it manual or anything that might help me with these problems? Thanks.
Old Jan 27, 2012 | 04:31 PM
noles's Avatar
Default Re: Minor problems
First I would check the fuse and see if its blown. Next I would go to the trunk and look at the Centrol Locking Module and check the connectors, especially if it is a convertible. Been there done that.
Old Jan 27, 2012 | 04:56 PM
Go here for practically every manual and repair manual you will need. download and save to your computer, back them up as well.
https://www.crossfireforum.org/forum...ollection.html
You need the 2005 repair manual.
By standing lights I guess you mean the parking lights. These may be on one fuse you can pull. These fuses are in the drivers end of the dash. Fuses #7 and #10 I think.
tcar32909
Aug 1, 2024 02:41 PM
nataliefs
Oct 5, 2015 01:03 PM
Den656
Sep 23, 2015 12:27 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
skeet370
29
Sep 18, 2015 05:53 AM
