Wheel Bearing replacement
Old Feb 6, 2012 | 01:19 PM
sleepydo's Avatar
Default Wheel Bearing replacement
Hi, my local tire shop said my front wheel bearing are bad. Are crossfire just regular taper bearing and not sealed type? do i need any special tools to replace it?
Old Feb 6, 2012 | 01:33 PM
Default Re: Wheel Bearing replacement
Autozone has the bearings for around $10 / set ( normal tapered bearings )
The service manual says no special tools required.
( if the hub race is scored, then you will need a new hub also ......
front hubs running around $75 on car-part.com )
NOTE: The XF has a 'clamp' nut, not the normal castle nut with cotter key
Old Feb 6, 2012 | 03:56 PM
turbomar's Avatar
2004-2008 CHRYLSER CROSSFIRE FRONT WHEEL BEARING KIT | eBay
Old Feb 6, 2012 | 05:01 PM
Perfect ! Bearings, races and seals .....
Old Feb 6, 2012 | 07:22 PM
stevedask's Avatar
How do you tell if you need the front or back, I hear a noise I think it's the wheel bearing but can't tell if it's coming from the front or rear of the car? Is there a way to tell when the car is jacked up if the bearings are bad at a particular wheel?
Thx
Old Feb 6, 2012 | 07:39 PM
turbomar's Avatar
You can start by jacking each wheel individually and check for wheel bearing play. Second, give each wheel a quick spin and listen for noise.
Old Feb 8, 2012 | 11:42 AM
sleepydo's Avatar
one on ebay is for supercharge.
turn out i just need new seals and just to repack the bearing.
autozone or advance auto doesn't sell seals.
Old Feb 8, 2012 | 11:48 AM
stevedask's Avatar
So you think the kit I just ordered from e-bay eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices is not for my N/A Crossfire?
Old Feb 8, 2012 | 11:54 AM
sleepydo's Avatar
on ebay there a wording in there saying A12 A13 and those are SC parts number.
N/a use A12 and A17 according to several other parts web site including Autozone.
i would call them to be sure.
Old Feb 8, 2012 | 12:15 PM
MikeR's Avatar
According to the parts manual the seals and bearings are the same for the NA and the SRT......
the difference is in the rotors and calipers...
Old Mar 6, 2012 | 08:01 PM
az2md's Avatar
SleepyDo,
I believe I have the same problem with my Xfire. How are you doing Nay?
Bora is going to replace mine the front wheel bearings for me. I will give you a call over the weekend!
Paul
Old Mar 6, 2012 | 08:09 PM
velociabstract's Avatar
I purchased these bearings (A12 and A13) and the boxes are stamped for Mustang II spindles. So I called them to be sure I got the right bearings, races and seals and they told me "according to Federal Mogul's cross reference guide" they are the same. We'll see. I'm having them installed Thursday or Friday. My front wheel bearings have a blue stripe from over heating. I repacked them but they are dead, dead, dead.
Les
Old Mar 6, 2012 | 08:22 PM
jmk41's Avatar
Wheel bearings are not something to play with on this car from experience! I had the drivers side front left bearing go bad out of the blue no warning or noise with in a second it was gone and spun the nut off leaving only my front caliper and rotor to hold the wheel on. The nut holding it all together is not reverse thread on the left side which makes this very likely given bearing failure.
Old Mar 6, 2012 | 08:23 PM
sleepydo's Avatar
paul,
i just repack the bearing with new grease and bearing seal then it was good to go. its very easy to do with old style taper bearing. you can pickup seals and bearings at advance auto parts store using SLK320 2004 model. advance auto got a good web site to indicate if your local store got the parts in stock.
hope to see you soon.
Old Mar 7, 2012 | 07:40 AM
az2md's Avatar
Great!
Thanks. I got the transmission filter, fluid and gasket changed recently and Bora did it for me. I had a very small minor leak (a drop or so every once in a while) so wanted to go ahead and did it as a preventive measure. Now this bearing issue :-)
Its my daily driver so these kind of things are expected I guess.
Talk to you soon.
Paul
Old Mar 10, 2012 | 08:34 AM
I bought this "kit" and the grease seals won't work. I installed the outside bearings and races and left the inside alone until I can get the right seals. Be aware if you decide to buy this kit from this vendor.
Les
Old Mar 10, 2012 | 08:41 AM
sleepydo's Avatar
thats for s/c model on ebay.
Old Apr 18, 2014 | 11:19 AM
mobilefitt's Avatar
quick dumb question. I have a set of spacers that are getting hung up on the front hub cap. Do you just use a screw driver (flat head ) to pry it off?
Once done, is there anything I should inspect when it's off as berrings and seals are cheap.
Thanks.
Old Jun 4, 2014 | 11:29 PM
turbomar's Avatar
Here are SKF and Timken part#'s for the front wheel bearings:
Roty135
17
Oct 11, 2018 10:11 AM
tom2112
Oct 26, 2015 08:18 PM
vinnys
Aug 14, 2015 10:42 AM
Jul 29, 2015 06:13 PM
Buchacho
Jul 9, 2015 04:13 PM
