power seat relay?
Old Feb 7, 2012 | 01:37 PM
CrossLover's Avatar
Default power seat relay?
we've had this intermittant problem for quite awhile where the seats lose all power (doors open & closed), then a short time later they work fine.
When the ignition switch was replaced under warranty, our selling dealer
basically refused to diagnose intermittant power seat failure. i've read on
our great forum about the seat relay repair after somewhat similar symptoms & I plan to take it to our new local dealer & insist that they replace the relay (before our extended warranty expires; 7/85 on '05
roadster, $100 deductible).
any comments, suggestions and/or identical symptoms?
62,000 miles & still in loveps;just read 180's post; should have searched first: Thanks!
Old Feb 25, 2012 | 11:09 AM
PRocha's Avatar
Default Re: power seat relay?
I ordered the relay for like 35.00 and took all but 10 minutes to replace, now everything works perfect.
Old May 31, 2012 | 12:02 AM
XFire-GTO's Avatar
Having same problem with both seats..... no movement in any direction.... seated in XFire, ignition in on position, or engine started, it dosen't matter......fuse #21 & 22 (30 AMP Green ) are OK
Have to be ordered through a Chrysler Dealer, or somewher else?
What is the part number(s) for the relay?
Are there seperate relays for each seat?
Where is the relay located?
Appreciate any help....Thanks in advance.
Old May 31, 2012 | 12:09 AM
tighed1's Avatar
180 did some work on this. Let me go search. BRB.
Old May 31, 2012 | 12:10 AM
tighed1's Avatar
Here it is
https://www.crossfireforum.org/forum...eat-relay.html
Old May 31, 2012 | 01:31 AM
XFire-GTO's Avatar
Originally Posted by tighed1
Thanks for the link..... forgot I had posted in that link 12/2010, and it seemed to be corrected at the time. Posted in that link the problem has resurfaced.
Thanks again!
07/19/2012.... issue appears to be resolved... click
Old Nov 4, 2014 | 02:58 PM
tonyrome1@sbcglobal.net's Avatar
can any out there tell how to replace a seat relay in a 2005 crossfire rosdster
Old Nov 13, 2014 | 10:23 AM
falshami's Avatar
yeah, how and where is it to replace, my seats are intermittent, also the drivers side heater on the seat doesnt function ... lights turn on the button but no heat and its winter, i need it!
Old Sep 2, 2021 | 08:48 PM
Jeffandmara's Avatar
I just purchased an 05 limited coupe convertible last week seats worked for about 5 minutes then they cease to work any longer after I read the articles on the forum I decided to try to exchange the seat relay myself.. lot of screws underneath the steering wheel dash however it was a pretty easy part to get to. I removed it got , all the numbers off the relay, and ordered one from Amazon for about $33. I should have it tomorrow in the mail. Hopefully once I replace the relay everything will be okay but if not I'll know it's the switch because the motor worked at one time last week
Valk
Jul 12, 2021 09:49 PM
Apr 28, 2016 02:04 AM
steps
Apr 26, 2016 06:21 PM
atdavis2
Sep 21, 2015 01:25 PM
tritongreen
Sep 18, 2015 07:32 AM
