Lighting!
Old May 8, 2012 | 03:19 PM
Default Re: Lighting!
They are not designed to come apart, although it has been done, I see in one thread where it was done with a Xacto knife, in another with a hot wire.
maxcichon says you can pour some 100% methyl alcohol in thru the little running light hole and get some cleaning done.
Old May 8, 2012 | 03:28 PM
Mrmiata's Avatar
Originally Posted by alaxfire
Yes, there are 2 additional bolts under each side, to get to the outside one, you remove the little plastic door in the fender liner and use a long extension.
This makes the HID installation MUCH easier,
HOWEVER !!!
Removing the headlight units will NOT allow you access to the projector lenses - they ALL look grubby, but that is just the nature of the beast.
Unless he wants to play the dremel game.. LOl. I hope at 55 watts you sprung for the relay kit?
Old May 8, 2012 | 06:42 PM
Another hint : after you remove all 4 bolts and the unit is loose, then remove the 2 aluminum screw things that the bottom bolts went in. This will give you the needed clearance to then remove the units from the car.
To re-install, get the units back in, then screw the aluminum nuts in all the way, snug down the upper bolts, then screw the aluminum nuts back out until they just touch the mounting tabs, reinstall lower bolts and tighten, then tighten the top ones.
Old May 9, 2012 | 12:29 AM
Gpeterson119's Avatar
I got my kits, and like expected, they didn't come with rubber grommets. What are the thickness of these usually? Do you think an old rubber inner tube from a bike tire would work? or does it need to be thicker
Old May 9, 2012 | 01:13 AM
Mrmiata's Avatar
Inner tube should work... just make holes in it (snug fitting )for the wires and slice it for the wires to slide into then use the adheasive of your choice to attach it to the OEM rubber cap.
Old May 10, 2012 | 02:44 AM
WHEW! I finished the install for the highs and lows! fogs tomorrow. It only took me 8ish hours lol. They look good! I ended up cutting a slit along the oem cap to a small hole in the bottom. This is where I routed all 4 wires. It looks very clean and I didn't have to cut or splice anything. I put the ballasts under each headlight stacked one atop another.
Problems I ran into.... I was unable to reseed the cooling tank back in that bloody hole.. so I just bolted it down and left it. If anyone has any tricks to getting it back in, let me know.
Also, it seems like my right head light is angled a bit to the right, I don't know if this is because of my instal, or if there is a trick to it.
Anyways I'm exhausted I'm going to get the fogs in then probably buff my headlights then ill take a picture.
Let me know if anyone has anymore info about ^^^. Hope this makes sense, I'm pretty tired
Old May 13, 2012 | 04:30 AM
GrantB's Avatar
Default
Anyone got any of the head lamp rubber caps for the rear of the lamp units, on of mine dropped off some place :-)
Regards
Grant B
QUOTE=Mrmiata;671416]Inner tube should work... just make holes in it (snug fitting )for the wires and slice it for the wires to slide into then use the adheasive of your choice to attach it to the OEM rubber cap.[/QUOTE]
Old May 13, 2012 | 04:49 AM
I don't have one, but if I run across it ill let you know
I accidentally didn't close my little door that leads to the fog lights... if anyone has an extra, I need it!
Old May 13, 2012 | 05:07 AM
GrantB's Avatar
Default
Thankyou.
Are the front fog lamps H7 bulbs like the headlamps.... if so i will get some 65 watt HIDs for them aswell.
Another thing i found on e-bay..... red coloured stop tail bulbs.... they make the rear lamps a deaper red and look even better.
I also got some amber lens paint in a bottle about the size of a bottle of nail varnish (no i dont wear mail varnish lol).....and added to the amber indicator bulbs..... look a nice deap flash now....
Have a great day you guys.
Grant B
UOTE=Gpeterson119;672151]I don't have one, but if I run across it ill let you know
I accidentally didn't close my little door that leads to the fog lights... if anyone has an extra, I need it![/QUOTE]
Old May 13, 2012 | 03:47 PM
Originally Posted by GrantB
Thankyou.
Grant B
[/QUOTE]
Good tips Grant! No, the fog lights are 9006. similar kit just different bulb housing. And, I bought chromed red lights for the rear blinker, I don't like amber that's why I'm looking for clear front side markers
Old May 15, 2012 | 06:36 PM
blwnstang02's Avatar
I love the hid's we put in our car. Xentec
Old May 17, 2012 | 01:16 PM
How do you keep your headlights so clean and shiny?
Old May 17, 2012 | 03:19 PM
Been waxing them since we got it, and it has 23-24k miles which helps.
2004_
Jul 9, 2025 12:39 AM
jgreen
106
Sep 18, 2017 11:46 PM
xfClifford
27
Nov 10, 2015 10:08 PM
KwehCat
Jul 16, 2015 04:48 PM
