Exhaust fumes in cockpit
Old Jul 4, 2012 | 06:48 PM
GrantB's Avatar
Default Exhaust fumes in cockpit
Guys.... suggestions plz ???
I have a normally aspirated manual XF...
At speeds up to 40 mph i get a whiff of exhaust smell inside.
From under the hood there is no sound of manifolds blowing, the exhaust is solid and none leaky.....put my hands over the pipes to test for leaks or blowing.... the exhaust pressurises and no blows or leaks evident at all....
The tail gate is a good fit and the rubber surround is good and no sign of deteriation....
However, there are some small water exit holes in the bottom of the tail hatch....
The engine does not blow smoke and the exhaust is clean....
Has any one else experienced this problem ???
When i speed up theres no problem....
Does the car tow a cloud of fumes behind it at low speed ????
I may try raising the spoiler and see if this helps....
Ideas welcomed before I die at the wheel from CO poisioning.
Thanks in advance.
Grant B
Old Jul 4, 2012 | 06:50 PM
user 72983's Avatar
Banned
Default Re: Exhaust fumes in cockpit
However, there are some samll water exit holes in the bottom of the tail hatch....
The engine does not nlow smoke and the exhaust is clean....
Has any one else wxperienced this problem ???
Thanks in advance.
Grant B
Mine is fine. Check out the exhaust system for leaks.
Old Jul 5, 2012 | 05:08 AM
waylander's Avatar
I'd go +1 for the leaks... mine seems fine at all speeds
Old Jul 5, 2012 | 07:54 AM
maxcichon's Avatar
Is it possible for you to have the very common breather cover (small valve cover) oil leak, and the burning oil smell is coming from under the hood?
Others have seen this.
Old Jul 5, 2012 | 08:19 AM
yes sir, Max I think has your answer, as there is the common valve cover leak, and some, have the dreaded transmission leak. Any fluid gets on the pipes, it will creat a smell. You could, even though not common, have a bad cat as well. Which can begin to stink. Time to put her up on a lift somewhere where you get her serviced and start looking...good luck..
TerryR
Dec 13, 2019 03:27 PM
cuziamninja
Oct 5, 2015 10:39 AM
Sep 28, 2015 07:40 PM
Big_Country
Sep 22, 2015 03:47 PM
stlas69
Sep 14, 2015 06:14 PM
