Uh oh, check engine light.
Old Jul 18, 2012 | 09:11 AM
MAYAman's Avatar
Default Uh oh, check engine light.
I know it could be anything, but for the first time in seven years my check engine light came on. Car is running fine. Any ideas?
Old Jul 18, 2012 | 09:47 AM
Default Re: Uh oh, check engine light.
Sorry, but you expect people to diagnose something that could literally be thousands of possibilities with zero info?
I would get the free code service at any auto parts store.
Old Jul 18, 2012 | 09:54 AM
MAYAman's Avatar
LOL sorry, just wondering if there's a "typical" thing that causes it to go off. On my other cars they all exhibit certain tendencies that narrows it down. But since I've never really had a mechanical issue with this car in the time I've owned it I wanted to see if anyone knows of "trends" with the Xfire.
I guess I'll hit up Pep Boys.
Thanks
Renntech carbon fiber intake. Borla exhaust. Eibach lowering springs. I think thats it.
Old Jul 18, 2012 | 01:50 PM
Thanks
The 'trend' would be CPS or the pump on the pollution crap oxygen sensors.
Old Jul 18, 2012 | 02:17 PM
MAYAman's Avatar
Whats a "CPS"?
I'm assuming the oxygen sensors are on the catalytic converter?
Old Jul 18, 2012 | 02:22 PM
vpats's Avatar
get a code .. then you'll know ... or at least where to start looking.
Old Jul 18, 2012 | 02:29 PM
There are a HANDFUL of things that it could be. We've seen CPS failures, clogged EGR valve, bad O2 sensors, bad air pump (180 mentioned that) and several other failures turn the light on.
The CPS is the Crankshaft Position sensor, a REAL common item to fail, sometimes it lights the light, sometimes it just fails and your car quits.
I've never had a failure, but I carry a spare CPS at all times, due to the problems others have had. They are hard to find and expensive locally, but you can order them online for as little as $50.
Old Jul 18, 2012 | 03:58 PM
MAYAman's Avatar
Ah great. Any tutorials on how to install it?
Old Jul 18, 2012 | 04:01 PM
Just wait to see what your code is first.
But yes, many posts here on changing it. No big deal.
Search "CPS"
Old Jul 18, 2012 | 07:31 PM
Then refer to this link / list to see what the code means:
Diagnostic Trouble Code (DTC) List
Old Jul 18, 2012 | 11:34 PM
dejohnny's Avatar
I've been dealing with these kinds of engine codes for the past 4 years, and what I've found is that you should always try the simplest things first. I've had the CPS replaced in 2008, oxygen sensors - 4 of them changed in 2009, and 2 more in 2011. I got screwed in both instances. I ended up paying the car dealer $2100 in all for repairs. After all that repair work, I still had the same problem. The engine would just cut-off in the middle of the road, no start issue or just sputter.
Typical Engine codes thrown:
p0410 - related to Catalytic Converter
p0562 - related to battery but it may be activated
p0335 - related to Crank Position Sensor CPS (sometimes this will indicate Engine misfires. It's possible to activate this to code when driving )
So the lesson learned is you should never underestimate the more obvious. Do a basic Tune-up, these cars love 'em.
Remove Air Box screws and remove Air Filters. You'll need a Torx-25 bit and driver-handle. Slap the dirt out of them and put them back in if your in a jam. Don't forget to replace them with new ones ASAP.
Very Basic Tune-Up
2 Cheap Air Filters (4 in a box): $18 - O'rielly's Auto Parts
Optional:
1 Bottle of Chevron Techron: $7 - At most Gas Stations
1 Full Tank of Gas: $48 - Depends on gas prices
Total: $73
Now, take your car on the highway and drive the HELL out of it for at least 150 miles!
Old Jul 19, 2012 | 01:11 PM
MAYAman's Avatar
^^^Awesome stuff man. Car is still running like new so I'm hoping its something simple.
skeet370
May 15, 2018 12:57 PM
jgreen
106
Sep 18, 2017 11:46 PM
wruss
Feb 8, 2017 01:05 PM
northwest_crossfire
May 30, 2016 05:19 PM
axnguyen
Jul 21, 2015 11:41 AM
