Remove Lower Grille
Old Aug 11, 2012 | 10:44 PM
TomStratRT's Avatar
Default Remove Lower Grille
Can anyone tell me how hard it is to remove the plastic lower grille on each side of the front bumper? I looked in all of the Crossfire manuals and couldn't find instructions for this.
I don't want to break anything.
Old Aug 11, 2012 | 10:49 PM
Default Re: Remove Lower Grille
Use a flatblade screwdriver and take 'em off!
There is a hole at the outer end of each one and you use a screwdriver to push the tab over while pulling out on the grill. It's easy once you "get it" and you can (well, I can) do it all with one hand - I put the driver in, press over on it, and pull at the same time.
Old Aug 11, 2012 | 10:50 PM
Of course, I've never owned an SRT.... not sure if they are any different.
Old Aug 12, 2012 | 02:46 PM
TomStratRT's Avatar
Cool thanks. I'll try that.
Old Sep 8, 2025 | 12:29 PM
lmshapiro's Avatar
This is absolutely correct. There are all these posts online about removing your bumper to remove the lower grills. Its nonsense. I have a 2006 Limited Roadster. It took me about 2 minutes to fish around with a screwdriver find the tab and remove the grill. I had to reattach the sensor (that senses outdoor temperature and has some effect on engine performance, I believe) that fits in the driver side lower front grill. Thank you Pizza Guy if you're still out there your comment is from 2009.
55chevy
Jul 22, 2024 02:31 PM
smokey847
Nov 12, 2015 11:54 PM
Ralph289
Sep 21, 2015 09:34 PM
ayebb
Sep 18, 2015 03:35 PM
jaesa
Sep 7, 2015 01:50 PM
