Xf headaches
Old Sep 13, 2012 | 10:00 AM
HORSIN'AROUNDXFIRE's Avatar
Default Xf headaches
listing tons of problems im having with my car.
1. headlights seem to be shorting out light bulbs every week if not twice a week. not fun when they are 10 to 15 bucks a pop.
2.moderate shaking in steering after reaching 55mph.
3. extreme camber on front tires(maxium life of tires 2 months)
4. squeaky brakes at low speeds but brakes are not worn or glazed over.
5. leaking oil(oil leak seems to be coming from the top of the oil filter, very slow leak but still a pain when my engine bay gets covered in oil)
6.ABS and ESP/BAS light have been on for a month now and ive done some research on it but have been scared out of troubleshooting from high cost parts that did not prevail for other crossfire owners.
7.this week coming home from my second job i was driving and my car random shut down on me and would not restart until i recieved a jump from a coworker. my second job is at autozone so i scanned my battery, alternator, and starter the next day at work and everything scanned good, its almost like the problem disapppeared beacuse it hasnt happened agian but that worries me with my crossfires inconvenient time for breaking down
8. searching for replacement parts for my xfire, Rear rim, front bumper, 2 new headlights, 2 new fog lights.
PLEASE LET ME KNOW IF YOU HAVE ANY IDEAS ON FIXING THESE PROBLEMS OR HAVE INCOUNTERED THE SAME ONES YOURSELF.
xfmadns- rapid city,sd
Old Sep 13, 2012 | 10:55 AM
Mrmiata's Avatar
Default Re: Xf headaches
Just wondering.. is your spoiler up with the ABS ESP/BAS light? I've replaced my wheel sensors with Johns from his crashed coupe.. now have a new battery in place since mine bit the dust .. and still have error. Thinking might bite the bullet on the pump/controller next. And of course it will then be the yaw sensor!
Old Sep 13, 2012 | 12:49 PM
RL67037's Avatar
Horse - since we do not know all you've done, some of these questions might seem rudimentary, so please don't take them as an insult. Just trying to get as much info as possible so the other experts on this site can chime in.
Thanks - RL
What is the make and model of the bulbs you are using?
Making sure you don't touch them with your bare hands?
Have you checked for corrosion at the connector and are you using the grease for bulb connections?
Have you had the alignment checked?
Have you changed the steering dampener?
Again, alignment?
Not sure on this one
Possible that the o-rings on the filter were not seated properly when it was last changed?
The ESP/BAS light might be able to be cleared by turning the steering wheel to the full left position, then to the full right position, then to center while the car is running. Have you tried that?
This might be the Crankshaft Position Sensor (CPS). Several threads on it and not too hard to replace. The part is about $50 bucks and be sure to buy the BOSCH part - not an off brand. While you are working this, you might as well do the re-soldering of the RCM to make sure that doesn't creep up on you. Also, check and clean your battery terminals - these cars are very voltage sensitive and a slightly loose cable or a little corrosion can cause strange problems.
I used Car-Part.com--Used Auto Parts Market and had good luck finding some replacement fog lights. You might find what you need there.
Old Sep 13, 2012 | 01:10 PM
maxcichon's Avatar
Is your car lowered? Front camber is not adjustable and should be ~ 1-1.5 deg negative (not sure of actual spec).
If your headlights are not cracked or otherwise damaged, just cloudy, it is pretty simple to recondition them. Many threads on this.
Oil issue can be resolved by changing the filter only-no need for a $65 oil swap too (assuming the oil is recent). New o-rings will be included with the filter. Mann, Purolator (fleece) or Mobil 1. Many threads on this too.
How old is the battery? Is it a white Valeo? Replace it. The sensitivity to voltage mentioned above is a legend here. Many have had their battery tested "good" and only fixed the issues with a new one. Go figure...
Old Sep 13, 2012 | 02:19 PM
Squeaky brakes are often cured by the use of anti squeal brake grease behind the pad and brake grease on the newly cleaned rubbing points of the pad and they slides they run on.
Turning the steering wheel lock to lock as stated will not solve the ESP/BAS light issue, normal driving does that very quickly.
It sounds like you need an alignment and probably the steering damper.
Bulbs do not short out, they work because they are dead shorts of positive to negative. Fluctuating voltage damages bulbs, high voltage will blow them in quick order.
Touching the glass will make the glass break in time due to stress in the glass caused by the oils on your fingers. Maybe you should try another brand of bulb.
Old Sep 13, 2012 | 03:41 PM
Mrmiata's Avatar
Or spend $30 bucks for the slim digital ballast HID kit on Ebay?
If the problem persist after that at least they are only 10-12 bucks for a pair of replacements till real problem is resolved?
Old Sep 13, 2012 | 05:26 PM
Default
Using the H7 lightbulbs. The passenger light is cracked but I have the most problems with my drivers side lightbulbs. My highbeams have never worked since I bought the car. The battery is only a year old and still extremely clean. The only "mod" I have done to my XF is side exit straight pipes and 275/30/19 rear tires. The car is bot lowered but have ruined several front tires but the tire will b full tread except for the inside 2 to 4 inches of the tires .I've trued turning the steering wheel lock to lock and back to center several times. To help troubleshoot the issue of the steering my steering seems to b extremely easy to the left but a noticeable difference when steering to the right. Car doesn't pull in any certain direction tho
Old Sep 14, 2012 | 02:48 PM
Gpeterson119's Avatar
Refering to #5 -the oil leak
I got this the first time I changed my oil
Fix: buy a oil filter cap socket tool and make sure your o rings are on right and oiled when you put them on.
Once I got that filter cap socket tool, I could crank it down really tight and have never had a leak since.
Old Sep 14, 2012 | 03:06 PM
chisler29's Avatar
#5 id say do the oil change yourself, or a garage you trust that knows about these cars. seems like the cap wasnt installed correctly.
#6. check to see if you have brake lights, also check your cruise controll if those doent work its your brake light switch. same thing happened to mine. its located behind the brake pedal. the part is about $120 from the dealership, you might be able to find it on line and just a 30minute job, much less if you know your way around a car.
#7 does sound like the CPS. you should get a check engine light though. pretty common issue with our cars, again 30 minute job.
Old Sep 14, 2012 | 11:34 PM
Mrmiata's Avatar
Chrysler Crossfire Right headlight | eBay
Seller also has a drivers side..
Old Sep 15, 2012 | 04:49 AM
Chris L.'s Avatar
Some of the filter kits (brands) that are sold as for the XF have O-Rings that are too thin.....thus leak.
I don't think any of the German Fleece kits have this problem.
I would only trust a Chrysler or Mercedes dealership to do an alignment on these cars.
Old Sep 15, 2012 | 01:48 PM
Jackerman's Avatar
Don't wanna thread jack but can anyone tell me how to align the headlights? My driver side is aimed downward and the passenger side is aimed straightfoward like its supposed to be ..
Old Sep 15, 2012 | 01:55 PM
Mrmiata's Avatar
Check the bulb.. they have a small notch to sit / align in the housing socket.. 9/10 times this is the issue.. installed my HID lights.. and knew I took the time to seat correctly... just to find drivers shining 5 feet in front on the ground..
onehundred80
Apr 16, 2025 04:43 PM
46Chiefpilot
Jun 14, 2015 03:17 AM
chrisificti0n
Nov 17, 2014 08:35 PM
MariposaRose
Jun 4, 2014 10:23 PM
afws04
Sep 7, 2006 02:16 PM
