engine hesitating
Old Oct 10, 2012 | 04:38 PM
GrantB's Avatar
Default engine hesitating
when my XF has has a bit of a thrashing for 10 minutes, the 1st 25% of the throttle pedal travel does NOTHING, The engine hesitates in all gears.... And the hesitation on throttling is the same whether moving or stationary....
The problem goes away if the engine is switched of and re started.... And all is fine until another thrashing and pushing the revs in all gears for 10 minutes......
Has any one come across this problem.... Or have any idea whats wrong?
Regards
Grant B
Old Oct 10, 2012 | 10:18 PM
Selbyl's Avatar
Default Re: engine hesitating
I had a similar issue the other day, there may be a bad hose. I popped off my engine cover and could hear a leak, the hose was left of the throttle body.
Regards
Grant B
Old Oct 10, 2012 | 11:51 PM
Warren Smith's Avatar
First I would check the codes. It sounds like a fuel restriction from what you have said. When you cut it off and start it again it has time to pick up more fuel. I don't know how many miles are on your car but I would consider changing out the fuel filter. Start with the small things and work towards the larger ones, not the other way around. JMO
janaiy
53
Nov 2, 2015 09:23 PM
RacerXofFL
Sep 15, 2015 05:00 PM
BEATv1
Sep 10, 2015 12:58 PM
MickeyNasty
Sep 6, 2015 08:29 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
