Do you burn 93, 91 or 87 octane in your CF?
Old Aug 16, 2004 | 11:16 AM
houstondan's Avatar
Default
Originally Posted by NJspeed69
You can't fault women though, they just don't understand this stuff, but I'd have her put some octane booster in it asap.
you know that scene where wiley coyote puts up the little umbrella as the shadow from the anvil gets bigger???
put up your little umbrella, nj.
dan
Old Aug 16, 2004 | 12:16 PM
WesMichaels's Avatar
Default
If that's the case (I couldn't find anything online about the 3.0 spec.s... My 4.0 Explorer is 9.0:1) it's the exception not the rule where compression is over 9.5:1.
Old Aug 16, 2004 | 12:26 PM
NJspeed69's Avatar
Default
Houstondan,
What the hell is that supposed to mean? Excuse me, but was I rude to you?
Old Aug 16, 2004 | 12:29 PM
Heb80's Avatar
Default
Luckily she didn't put diesel in it.
They should make the gas nozles different size for premium and regular so that people don't make that mistake. They do it for diesel.
Old Aug 16, 2004 | 01:39 PM
houstondan's Avatar
Default
Houstondan,
not at all...it was an attempt at humor in suggesting that your attitude toward women was going to be noticed. obviously, i was wrong.
dan
Old Aug 16, 2004 | 01:47 PM
Rob M's Avatar
Default
Wes,
I looked at some specs on other cars and there are more than I thought running 10:1 compression on regular unleaded fuel. Example: Honda Accord V-6 @ 10.0:1. I think the reason they are able to do this for ratios over 9.5:1 is by using aluminum heads.
Old Aug 16, 2004 | 04:19 PM
Default
I would think that aluminum heads would be more easily pitted by predetonating fuel. they must be using much richer fuel scheduling. If it ever gets lean they will have major problems..... I would think. The knowledge I have on the subject is old school but has been common knowledge about compression and fuel octane since I was a kid. Of course we didn't have computers checking things like the O2 level in the exhaust gases to make sure the engine doesn't run too lean. It may very well be possible, I guess, for the ECU to make running lower octane fuel in higher compression engines safe. By keeping the fuel mixture on the rich side and retarding the igition timing on the fly.
Rule of thumb is.... If it's not pinging, you're okay..... That's a rule that I don't think will ever change.
Old Aug 16, 2004 | 05:17 PM
Rob M's Avatar
Default
the aluminum heads allow for greater compression ratios because they are superior at dissipating heat. it's the lower temperature that prevents the fuel/air mixture from predetonating at up to 10.0:1.
Old Aug 16, 2004 | 06:10 PM
Default
That makes good sense.
Old Aug 17, 2004 | 02:13 AM
CFbabe's Avatar
Default
This female knows the difference between those little numbers on the gas pump. I go with the Premium gas. Always will in the Crossfire. Geez guys, give us gals a break. LOL :shock:
I maybe blonde, but don't let it fool you. :wink:
Old Aug 17, 2004 | 03:29 AM
r.robertson's Avatar
Default
I Use Shell optimax or BP ultra. Don't know what the ron is but would expect around 97-98. Someone told me that, after reading the shell web site, optimax was listed at 104 ron but can't confirm as I did not read myself.
Old Aug 17, 2004 | 01:26 PM
english_bob's Avatar
Default
On the inside of my filler cap (UK spec) it states use EN228 RON95. I intend to experiment with RON98 next month to see if it makes a difference to 1) Performance and 2) Economy. I need to justify the extra 7p per litre for the extra 3RON.
Nice to know that the UK and US specs for fuel are different. You would think that it was possible to have one rating across the world for international fuel and car companies.
Old Aug 17, 2004 | 03:20 PM
the sarge's Avatar
Default
shell Optimax is 98.3 - 98.6 RON
Old Aug 17, 2004 | 03:58 PM
David Burns's Avatar
Default
I wonder if "Optimax" is the same/similar as "V-Power" :?:
http://www.shell.com/home/Framework?...t_ga_1602.html
http://www.shellvpower.com/
Old Aug 17, 2004 | 05:44 PM
jsisabella's Avatar
Default
I use either Shell or Marathon 93 Octane.
The price at my last fill up was $1.989 per gallon.
With the air conditioner running, I am getting about 21 mpg with an even city/highway mix. With the air off, it goes to about 23.5 mpg.
Old Aug 18, 2004 | 02:13 PM
NJspeed69's Avatar
Default
Sorry about the misunderstanding Dan. No problemo.
Anyway I try and always use BP because they claim to remove all the impurities most companies leave in, making their fuels cleaner and more efficient. Whether it really is all true or not, I dont know.
Old Aug 18, 2004 | 03:15 PM
shawd's Avatar
Default
I use Shell 92 oct........... 8)
srtmodder
Aug 23, 2017 08:28 PM
Oct 1, 2015 01:42 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
flame
Jul 20, 2015 08:46 PM
Brewen23
Jul 20, 2015 03:13 PM
