Needswings srt intakes
Old Jan 6, 2013 | 01:30 PM
MarkRen.'s Avatar
Default Needswings srt intakes
Has anyone tried these on a NA engine? I've been looking for ways to get a faster 6speed and a lot of posts go unanswered besides saying get an srt. I still haven't found anyone who has bought a new cam or swapped the 3.7 block besides renntech. Sooo I think we need to start experimenting instead of condemning our 6 speeds by saying they're weak. There is a company who makes clutch kits for the slk320 and crossfire they're just vague in the descriptions.
Old Jan 6, 2013 | 01:45 PM
grip grip's Avatar
Default Re: Needswings srt intakes
I belive the Needswings NA intake and SRT intake flow the same CFM, so there shouldn't be a difference in performance.
Old Jan 6, 2013 | 02:43 PM
Mrmiata's Avatar
Since they make ones to fit the NA.. can someone explain the need to put the SRT6 intake on? Does being labeled SRT6 make it faster? If so I'm off to Ebay.. noticed some go fast body badges!
Old Jan 6, 2013 | 02:50 PM
Marky my boy they don't work on the n/a engine since it doesn't have a supercharger. There is thread after thread about modding the n/a model. A lot of those mods aren't available anymore as well.
Old Jan 6, 2013 | 06:53 PM
Selbyl's Avatar
I did find a company that makes cams for our engine I sent them an email with the cost for everything. It's safe to assume it might be an arm and a leg.
Kleemann - Tuning for the 32 AMG/320 (M112) V6 engines.
Old Jan 7, 2013 | 07:52 AM
SRT6 Gang Member's Avatar
THREE 6S
If you mentioned the words, Chrysler or Crossfire, in that email you may not get a response.
Old Jan 7, 2013 | 10:03 AM
You also may want to insure the internals will support this camshaft. Our cars have the E32 version ( http://en.wikipedia.org/wiki/Mercedes-Benz_M112_engine ), the others have a different version of the M112. You may buy a cam that will not work without a few internal mods. I am not sure the lower end (block) is identical, maybe you should check a lot further, seeing as you seem to have a coupe?
Old Jan 7, 2013 | 06:29 PM
Selbyl's Avatar
You also may want to insure the internals will support this camshaft. Our cars have the E32 version ( Mercedes-Benz M112 engine - Wikipedia, the free encyclopedia ), the others have a different version of the M112. You may buy a cam that will not work without a few internal mods. I am not sure the lower end (block) is identical, maybe you should check a lot further, seeing as you seem to have a coupe?
I just got an email back from Kleemann:
Hello Selby-
Thanks for taking the time to write!
Our product offerings for your 2005 crossfire are limited, unfortunately. The Crossfire is based on the Mercedes-Benz SLK Chassis (R170). That being said, KLEEMANN never developed headers for that particular chassis, so the only products available are ECU tuning and camshafts.
ECU Tune: $595.00 +15-20 HP/TQ, improved throttle response, removal of the top speed limiter.
Sport Camshafts: $2495.00 +15-20 HP, +15 TQ
These are the only two products KLEEMANN still offers for the M112 engine- I'm afraid our supercharger system for that engine was discontinued about 2 years ago.
If you have any other questions or concerns, please don't hesitate to let me know.
Thanks again!!
Cory Umemoto
Technical Manager"
So the Cams are a lot cheaper than I thought. Still not cheap.
Old Jan 8, 2013 | 10:08 AM
sk8erjosh09's Avatar
For the price and performance listed you may as well just do a motor swap.
Old Jan 8, 2013 | 12:58 PM
S. Artee's Avatar
That's certainly not as bad as I was expecting.
Hello Selby-
Thanks again!!
Cory Umemoto
Technical Manager"
Old Jan 8, 2013 | 09:52 PM
itsky's Avatar
The SRT-6 intakes are not labelled any differently than the N/A ones. I'm not absolutely certain that the SRT-6 intake would fit on an N/A though.
Old Jan 8, 2013 | 09:59 PM
Mrmiata's Avatar
I was thinking "new purchase"... why buy SRT..
But I guess if you had an NA and could score a used SRT system for a few hundred less... it would be a valid question..
Old Jan 8, 2013 | 11:51 PM
rmaier's Avatar
It could fit with some tweaking.........no gain over the n/a needswings intake tho
Old Jan 8, 2013 | 11:56 PM
itsky's Avatar
Robert, I see that you have an '05 SSB srt6 listed in your sig. Did you go out and buy another one???
Old Jan 9, 2013 | 12:09 AM
JHM2K's Avatar
Slight difference in the Y-pipe area:
Limited:
SRT:
Old Jan 9, 2013 | 12:11 AM
JHM2K's Avatar
Cory is the man, I'm glad you got in touch with him. He has been very helpful to me over the years.
Old Jan 9, 2013 | 09:45 AM
rmaier's Avatar
Good images to show the diff in the connection to the tb area.....still could be made to fit but what would the point be ......all things being equal. Unless you got a heck of a deal on the srt6 I'd stick with the 1 made for the application.
Yes Evan I bought the car and had it shipped......needs some surgery before it can be back on the road again. Gathering all the parts right now and taking everything apart to see all the things to make it right with the world again. You can come over and check it out....... or wait until spring when we have another run.
Robert
Old Jan 9, 2013 | 11:22 PM
itsky's Avatar
Robert
Sounds good. I'm sure you will make it right again. We'll have to plan our next CCC event soon.
Old Jan 10, 2013 | 07:25 PM
Cold Air Intake...... I was thinking intake manifolds... when you just stated intakes...my bad...
4drturbo
Jan 3, 2019 02:46 PM
waldig
Jul 31, 2017 09:46 AM
waldig
Jul 20, 2015 08:10 AM
UNDER PSI
Jul 18, 2015 02:12 PM
bradleykologek
Jul 6, 2015 02:49 PM
