Service warning SPANNER/WRENCH
I do my own oil/filter and service part changes as per the book, some 9 > 10,ooo miles or less.
And the display is marked up with a wrench symbol for a minute or so each time I start the vehicle.
Is there a way/procedure to get this to vanish ???
I use the throttle reset procedure every month to reset the pedal, is there some thing silmilar to clear the display ??
Cheers
Grant B
Cheers
Grant B
I had this info saved...
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE
1. Move the ignition switch to the “RUN” position.
2. Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second. The display for the FSS service
request is activated for 10 seconds
3. During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position.
The FSS service request will continue to be displayed.
4. Press the reset button for the trip odometer and
hold.
5. Move the ignition switch to the “RUN” position
6. Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display.
The tool symbol should disappear at this time.
This was posted by Andrew in a previous post on the forum. (He has alot of answers to questions on this forum). Just read it thru several times before doing the reset. It sounds more complicated than it really is.
hold.
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
