New KYB Shocks
Old 05-23-2014, 07:11 PM
mobilefitt's Avatar
Default Re: New KYB Shocks
Do KYB bump stops need to be shaved on the crossfire if I have eibiach springs pro-kit?
Old 08-30-2017, 02:20 PM
Those of you that put these KYB shocks on your car. [KG4731 & KG4732] Did you find that the ride is really bouncy? I feel like I am riding on the springs the entire time when I am driving.
I had a mechanic put these on for me, and I am about to go in to have someone else from his garage look at them to be sure they are installed correctly, but I can't imagine that there is much he could have messed up. Seems like a simple enough install.
Thanks,
XfireCrazy
Old 08-31-2017, 03:34 PM
Originally Posted by DTMenace
Bill F
Those are the part numbers for the Mercedes Benz SLK shocks manufactured by KYB, so the logic is they will fit the Crossfire since it was built on a similar platform. The pricing is between $200-$250 including shipping.
Dennis
DTMenace
The shocks may be different when you consider that KYB was testing them on the Crossfire. Why test on the Crossfire if they're identical to those used on the SLK320 and the suspensions are the same? Although the Crossfire is built on an SLK320 chassis, I've read that the SLK320 suspension was slightly modified for use on the Crossfire. A return warranty is a good idea if we by the SLK320-spec'd shocks.
Old 09-01-2017, 07:27 AM
maxcichon's Avatar
Eibach (lowering springs) made it clear I would have to trim the OEM bump stops to 1/2 the original length.
If one ignored that, I think you would hit the stop quite often.
Old 09-01-2017, 04:39 PM
Thanks,
XfireCrazy
SOLVED: The mechanics had put the front shocks on the rear and the rears on the front. Got them swapped out and now the car is nice and stiff again.
Thanks for all the advice and support.
jefecito (02-15-2023)
Old 04-15-2022, 03:56 AM
Shock absorbers KYB 553364 /REAR/ price in Czech Republic for both cca. 130,- dol.
They have greater rigidity than the Mercedes SLK 320- LARGER REAR WHEEL SIZE!!!
Replaced a month- working OK!!!
deerhunter
01-16-2021 10:56 AM
2005 Ragtop
10-03-2015 03:01 PM
SRTFAN
08-27-2015 01:25 PM
ttosh
07-31-2015 11:06 AM
shawnwatson9493
07-09-2015 11:47 PM
Quick Reply: New KYB Shocks
