Local Mechanic in Orlando Florida Area
Old Mar 11, 2013 | 08:11 PM
juliewestfall's Avatar
Default Local Mechanic in Orlando Florida Area
I took my car in today because I had a lot of problems and now I want to sell my car. Should it really cost this much? I looked at the part prices online and I'm being overcharged but need local mechanic.
1. RELAY CONTROL MODULE - PART 384 INSTALL 99.95
THERE ARE CODES IN THE COMPUTER FOR OXYGEN SENSOR, EGR CIRCUIT, AND SECONDARY AIR INJECTION PUMP THAT MAY BE RELATED TO RELAY CONTROL MODULE, BUT I AM UNABLE TO TEST FURTHER UNTIL RELAY CONTROL MODULE IS REPLACED BECAUSE THEY ARE ON THE SAME CIRCUIT.
2 WATER PUMP AND AC COMPRESSOR MAKING NOISE AND MAY CAUSE THE BELT TO COME OFF SO THEY SHOULD BE DONE TOGETHER. WATER PUMP PART 747.00 INSTALL 260.00 AC COMPRESSOR PART 1450.00 INSTALL 350.00
3. COOLANT BOTTLE LEAKING PART 82.00 INSTALL 30.00
4. AIR FILTER 69.95 INSTALL 30.00
5. SPARK PLUG REPLACEMENT PARTS 360.00 INSTALL 150.00
6. OIL AND FILTER CHANGE 85.00
7. ENGINE DECARB 139.95
8. INJECTOR FLUSH 119.95
9. VALVE COVER GASKETS AND PCV CHAMBERS LEAKING OIL PARTS 53.00 INSTALL 399.95
Old Mar 11, 2013 | 08:46 PM
Mrmiata's Avatar
Default Re: Local Mechanic in Orlando Florida Area
Wow.. thirty bucks a plug huh... not on your life.. plugs and wires.. we'll okay.. relay control module.. probably just the solder joints.. tv repair shop and 10 bucks..compressors on ebay for a few hundred....water pump.. he flying it in from Europe? Yeah.. you need a member with some spare time .. you could pay him a healthy wage and save a ton on this.
And I hope those are K&N filters at that price... 30 bucks for one pull and 8 screws.. well guess that a bargain some places.. but not in your case..
Old Mar 11, 2013 | 11:25 PM
Mrmiata's Avatar
Chrysler Crossfire New A C Compressor Kit | eBay
Good example of there price vrs what is available.. I'd say run..
Or bring your own eggs to the breakfast table they are serving up...
Old Mar 12, 2013 | 08:34 AM
GrantB's Avatar
I think this mechanic must have seen the AmEx Gold Card in your wallet, and thought you were daft enough to fall for all that lot....
None of those jobs are technical or difficult, tho some are fiddley and irritating to do...
At that rate, you can afford to take 3 weeks off work, sit on your *** for 2 weeks and enjoy the sunshine, and then take your time doing the fix-its over a few days, and you will still be quids-in I recon lol
Old Mar 12, 2013 | 01:15 PM
thank you so much for the feed back, I'm a girl so cant do myself willing to hire someone in the Deltona Daytona Beach area. I know my son said that sounds way too expensive, but he lives 1000 miles away.
Old Mar 12, 2013 | 02:23 PM
Julie, that's a total ( I'm sure you already added it all up ) of $4,810.75 !!!!!!!!!
Use the Quick Links / Members List then click on "Search Members", then "Advanced Search"
This will allow you to search all of Florida or by city. There should be someone in the list that is still active that could help you out.
( mimisrt6 comes to mind )
Heck, for that kinda coin, drive up here and I help you for a mere 10%.
( only 492 miles [ 8 hours ] each way ....... )
Old Mar 12, 2013 | 02:30 PM
Mrmiata's Avatar
Red Dog is down that way.. but I have no clue if he knows which end is the open end on an open end wrench..
Old Mar 12, 2013 | 02:41 PM
He's all the way down in Key Largo ....... ( 326 miles away )
Old Mar 12, 2013 | 02:47 PM
Mrmiata's Avatar
Soooo ... Pack a lunch?
Old Mar 12, 2013 | 02:48 PM
Mrmiata's Avatar
Isn't there a Florida group? Seems like I've caught wind of one with a facebook page?
Old Mar 14, 2013 | 01:50 AM
Wouldn't it be nice if you found a member to help you fix it all better and you KEPT it? Now that would be an awesome end to this story...
Old Mar 15, 2013 | 03:30 PM
syfi's Avatar
I just PMed you...
Old Mar 15, 2013 | 03:33 PM
Mrmiata's Avatar
Originally Posted by syfi
I just PMed you...
YOU DA MAN! (unless your making a low ball offer to buy..)
RED DOG
Crossfire Events and Meets
Nov 1, 2021 12:29 AM
Helot
Aug 15, 2015 04:19 PM
UNDER PSI
Jul 18, 2015 02:12 PM
Bayukbros
Jul 17, 2015 11:21 AM
Mackel
Jul 6, 2015 10:54 PM
