price check
Old Apr 30, 2013 | 09:20 PM
whoosh's Avatar
Default price check
Found a gray 2004 coupe auto with 33000 miles, stored winter for 7500.00. Only negative things are rear tires are loud as hell when slowing /braking, sounds like a four wheel drive with mud tires.The tires are not very loud at highway speeds. The other negative is the tilt wheel lever seems disconnected and doesn't release the steering wheel so it can move. The owner bought is from a dealership with 16000 miles on it in 2009. What do you think of the price?
Old Apr 30, 2013 | 09:25 PM
Default Re: price check
price is right...thinking about your tire noise.. it could be the camber is out if this car has been lowered....how do the rear tires look when you see it from behind. Are the wheels straight up and down or do they seem to look tilted a little...
Old Apr 30, 2013 | 09:56 PM
Sandy's Avatar
Good price! Even if you need to buy new tires, it's still a good price!
Old Apr 30, 2013 | 10:22 PM
+fireamx's Avatar
Uhh...You do know the steering wheel will NEVER tilt. (It just moves forward and back).
Old Apr 30, 2013 | 10:35 PM
itsky's Avatar
I had a set of Goodyears on one of my old Crossfires. They sounded like my old Jeep Rubicon. As soon as I replaced the tires, the noise went away. As +fireamx stated, there is no tilt steering on a Crossfire. The price sounds great for that amount of miles.
Old Apr 30, 2013 | 11:03 PM
Buy of the decade, last Graphite (6 speed) coupe I saw for $7995 had 96,000 on it.
Sounds like it just needs tires to me.
Old May 1, 2013 | 12:47 PM
Ed Mahoney's Avatar
I just replaced the tires on my Stang had only 10,000 miles on them ! Same thing they started to get loud as hell !!! Went with sumitomo s great price at tire rack !!! Mine where 245/35 - 19 only $550 for all four mounted & balanced !!!
Old May 27, 2013 | 02:43 PM
whoosh's Avatar
Went this Saturday and bought the xfire. It had 32997 miles on it when I picked it up. The car is in fantastic condition inside and out (always stored for the winter) and well maintained. Car Came with two key fobs and original window sticker. I did have to fix the telescoping column, the pin that attached to the release pull was missing. I will post a link to photos sometime soon.
Old May 27, 2013 | 02:51 PM
Bigkid's Avatar
Congrats and welcome to the forum. Sounds like you got a good one.
Old May 27, 2013 | 02:56 PM
Bigkid's Avatar
Sorry whoosh did not notice that you have been around since 2008.
Old May 27, 2013 | 03:39 PM
That was a hell of a buy, and it's the right color, too.
Old May 27, 2013 | 05:03 PM
whoosh's Avatar
I do love the gray. At this price I would have taken any color.
Old May 28, 2013 | 01:40 PM
arejohn's Avatar
I want it. Where? Tire noise is most often caused by feathering- tire blocks feel like saw teeth- incorrect toe. Usually a front problme so I suspect tires recently rotated?
Old May 28, 2013 | 08:20 PM
whoosh's Avatar
arejohn, you are correct, front tires are feathered. I plan on getting a new set of tires as soon as I can decide on what kind to buy. Alignment will be done after I inspect front end components.
Old May 28, 2013 | 08:54 PM
whoosh's Avatar
Did I read correctly, toe in front is not adjustable on these cars?
jgreen
106
Sep 18, 2017 11:46 PM
deerhunter
Sep 2, 2015 10:36 AM
Freezer
Aug 6, 2015 07:24 PM
Tp'sfury
Jul 17, 2015 01:15 PM
James1549
Jul 6, 2015 10:36 PM
