tires
Old Aug 6, 2013 | 10:52 PM
kiarenee's Avatar
Default tires
Will 245 40 18 tires fit on the front
Old Aug 6, 2013 | 11:05 PM
Default Re: tires
I think they will - but unsure of the handling you'll get.
There are a LOT of tire threads, you might snoop around here: Wheels, Brakes, Tires and Suspension - CrossfireForum.org
and see what others have done. MANY of us are running wider, larger tires on the rear (I run 285/25/19) and LOVE the cornering and slight slower cruising rpms.
I'm just unsure of how it will handle with those up front...
Old Aug 6, 2013 | 11:28 PM
kiarenee's Avatar
Default Re: tires
Its a daily driver. I want to know if I will have rubbing problems with 245 40 18 on the front. I have 255 40 19 on the back any good combinations for that
Old Aug 6, 2013 | 11:45 PM
Default Re: tires
I REALLY think they won't rub. I just cant' say for sure.
If no one chimes in by morning, or you are in a hurry , go look around in the forum I showed you and see what people are getting away with.
I know my 285's in the rear are FINE, even in heavy turns at speed.
But I DO know that guys have had tires rub up front, it SEEMS, a lot - but those were lowered cars, if I remember right.
I've never used anything but OEM size up front.
Old Aug 10, 2013 | 05:38 AM
shawndalyphd's Avatar
Default
The place that rubs first on the fronts is the suspension bolt on top of the wheels. The stock distance is about 1/2" (give or take). You might get 235 in there, but no way 245. The only way to get 245 is a 10mm spacer.
Shawn
Old Aug 10, 2013 | 08:36 AM
MJPowers's Avatar
Default Re: tires
I ran 245 40 18s for autocross with a 10mm spacer. Didn't rub on the top bolt, but under hard cornering & braking I did rub the plastic fender liner. With 10mm hubcentric wheel spacers, shouldn't be a problem as a daily driver.
TerryR
Dec 13, 2019 03:27 PM
Jonacross
20
Jul 17, 2017 11:19 PM
Mackel
Sep 29, 2015 02:41 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
stelrz1
Sep 21, 2015 11:18 AM
