So I hit the gutter, really hard! need help
Old Sep 16, 2013 | 10:31 AM
dom03's Avatar
Default So I hit the gutter, really hard! need help
Guys,
Crossfire 2004 Coupe (Australia)
I lost control around a roundabout in 2nd gear with traction off (I know I know ). Car fish tailed because of loose gravel all over the road and I did a "perfect" 180 degree turn and smacked the car perfectly side on into the gutter at around 50-60km/h... let me tell you the smack was so loud I was 100% certain i just wrote off my car!
The rear-right rim hit the gutter and took all the impact, the rest of the car and body was without a single scratch (I was amazed!)
So the damage.... rear right control arm bent, shock leaking, and the rim has minor crack, see pics below. The rear right wheel is not sitting flush anymore, its slightly bent (obviously due to the control arm)
Location/Scene: http://oi44.tinypic.com/aox7vc.jpg
Cracked Rim: http://oi40.tinypic.com/2qvvywp.jpg
Bent Control Arm: http://oi41.tinypic.com/34rx5cl.jpg
Bent Control Arm: http://oi44.tinypic.com/25t7n6w.jpg
I took it to get a full detailed suspension inspection to identify the damaged parts, and the following requires replacement (some parts are from wear and tear over the years). I need help locating these parts?
Front Suspension:
1. Lower ball joint (excessive movement, require replacement)
2. Drag link (excessive movement, require replacement)
3. Steering damper (leaking)
4. Power steering lines/belts/filter/oil (belt frayed, requires replacement)
Front Brakes:
Brake fluid condition (contaminated, requires flush)
Front pads (nea rmin thickness, recommend replacement)
Front rotors (below min thickness, require replacement)
Rear Suspension:
Shocks (RH leaking, requires replacement)
Lateral arms - lower (Arms bent)
- Can anyone please direct me to where I can source these parts online (I am from AUS and happy to ship them here from the US), they must be original genuine parts, I wont do cheap alternatives (unless they are a superior product)
Old Sep 16, 2013 | 07:24 PM
Default Re: So I hit the gutter, really hard! need help
Sorry to hear of your incident
You might be able to get your parts from
MrMoPar
Welcome to the Crossfire Shop!
Old Sep 17, 2013 | 01:36 PM
Ed Mahoney's Avatar
50 MPH GOING INTO A ROUND ABOUT !!!! THOUGHT THEY SAY 15 MPH !!!! OH WELL LIVE & LEARN !!!!! Best to hunt for used parts at the bone yards !!! Good luck !
Old Oct 12, 2013 | 11:48 PM
dom03's Avatar
50km/h
Anyone know if this website is reputable and well priced?
Chrysler Crossfire Parts - Chrysler Crossfire Accessories at Auto Parts Warehouse
Old Oct 13, 2013 | 12:27 AM
dom03's Avatar
Could anyone recommend aftermarket high performance parts instead of OEM that are better for thecrossfire? the parts I need are listed above, i.e with the shocks are there any suggestions for better performing ones than OEM?
Old Oct 13, 2013 | 04:00 AM
dom03's Avatar
Could someone please help me verify these are the correct part numbers?
Front Suspension:
1. Lower ball joint (excessive movement, require replacement) 05099237AA
2. Drag link (excessive movement, require replacement) 05098996AA
3. Steering damper (leaking) 05097971AA
4. Power steering lines/belts/filter/oil (belt frayed, requires replacement) 05097758AA
Front Brakes: Can anyone suggest some high performance aftermarket brake discs, pads, and rotors (complete brake system kit upgrade)
Rear Suspension:
Shocks (RH leaking, requires replacement) 05096751AA
Lateral arms - lower (Arms bent) 05143012AA
smfrycruzr
Jul 17, 2023 05:33 PM
blackpepper
Oct 4, 2017 06:09 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Sep 26, 2015 10:21 PM
xjken
Sep 13, 2015 10:18 PM
