Whistling sound from a/c
Old Oct 8, 2013 | 10:03 PM
ronw57's Avatar
Default Whistling sound from a/c
First time poster. Have owned a 2005 Crossfire for little over a year. Very little mileage. Today, for the 1st time, I heard a whistling sound (very shrill sounding) coming from the air vents. It is not continuous but off and on. When it happens, shutting off the a/c makes it stop. But once the a/c is turned backed on, it happens again within a few seconds.
No warning lights have come on. Any ideas or suggestions are welcomed. rw
Old Oct 8, 2013 | 10:13 PM
Default Re: Whistling sound from a/c
Maybe there is something stuck in the ducts somewhere, or the air filter/fan area.
Old Oct 8, 2013 | 10:36 PM
Ottawa John's Avatar
That would be my first guess too. Have you listened with the hood up to see if the sound starts or stops with the A/C compressor operation? If you only hear the sound with the A/C on and compressor engaged, then that may be your source too.
Old Oct 9, 2013 | 12:39 PM
ronw57's Avatar
I am hoping it is not thecompressor ($$) but it does make sense. I will try your troubleshooting suggestion.
Old Jun 21, 2016 | 01:00 PM
bsb6's Avatar
Did you ever figure out what is/was wrong.
I get the same whistle when a/c is off, setting the fan to lowest setting will stop it, that is unless I use the a/c, then it whistles and any fan speed.
I am thinking it is some vacuum leak, as it comes and goes while driving, steady speed there is no whistle, back off the gas and it begins. Feather the gas and it eases then goes away. When it whistles while the top is up it can drive you nuts.
I know it isn't debris in the blower housing. Anyone have an idea?
Thanks,
Old Jun 21, 2016 | 01:18 PM
Padgett's Avatar
I'd replace the cabin air filter first, a clogged filter can really whistle.
Old Jun 21, 2016 | 04:04 PM
kingdavid54's Avatar
Also make sure all of your vents are open that will cause a whistling also at least it did on mine
Old Jun 22, 2016 | 09:35 AM
bsb6's Avatar
Thanks to both of you. I'll give it a try after work today and let you know how it goes.
Old Jun 23, 2016 | 07:26 PM
There are flaps that are actuated by vacuum, there is also a white valve behind the dash that has caused problems, a leak in one of the these might cause a whistle.
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
brandoni
Sep 30, 2015 07:48 PM
debradegiovanni
Sep 27, 2015 09:39 AM
BEATv1
Sep 10, 2015 12:58 PM
