Headlight Adjusting rotation switch
Old Nov 28, 2013 | 07:22 AM
D&NIS's Avatar
Lightbulb Headlight Adjusting rotation switch
Hi all,
I have a little problem with the headlight adjusting in my crossfire.
I tried to aim the headlights a little higher using the switch. They were positioned on the lowest position, so pointed a bit towards the ground.
When i switch up 1 step, the headlights come up a bit higher. On the following steps ( i believe there's like 5 orso) the headlights don't move up at all.
Anyone got an idea where to look for a problem first? or did found a other thread with the similar problem because i could find it.
All advice will be much appreciated.
Greetings D&nis
Old Nov 28, 2013 | 08:15 AM
Default Re: Headlight Adjusting rotation switch
You would probably be a step ahead if you posted this on the UK forum, the US cars don't have this feature ( sadly )
Old Nov 28, 2013 | 08:31 AM
D&NIS's Avatar
That explains allot, i could find anything in the Chrysler documentation about it.
Mine's imported from Germany.
Thanks for the advice.
Old Jan 17, 2014 | 03:45 AM
D&NIS's Avatar
Any UK members got some clue's??
Old Jan 28, 2014 | 06:53 AM
D&NIS's Avatar
Really nobody??
Old Jan 28, 2014 | 09:39 AM
Originally Posted by D&NIS
Really nobody??
There is only a couple of people in the UK who reply to some of the queries here. They tend to ignore us until they want something. Isolationism I think they call it.
Most of their questions and replies are on the UK forum.
Try to ask your question there.
Old Jun 15, 2015 | 05:21 AM
SuperD500's Avatar
Really nobody??
Maybe a little late, but for the sake of an answer ...
Although there's several clicks while rotating, it has only 1 level. As also indicated on the switch, with a single '1' figure.
I've had a similar discussion during the mandatory yearly safety inspection (“APK“) and had to convince the inspector that it has only 1 level.
Lockhouse
Mar 20, 2024 04:50 PM
Franc Rauscher
May 9, 2016 12:04 PM
UNDER PSI
Nov 1, 2015 09:39 PM
Reliableron
Oct 17, 2015 10:19 PM
RacerXofFL
Sep 15, 2015 05:00 PM
