Idle issues
Old Apr 10, 2014 | 06:31 PM
matth189's Avatar
Default Idle issues
Today when I was driving my car it was running fine and all of a sudden it just died while I was driving. Then after I started it again it wouldnt idle, it would turn over and start but would keep stalling. Then once I got it driving down the road again, every time I would push in the clutch and put it in neutral to just roll to a stop it would keep idling up to 2k then fall to 1k then back to 2k and back to 1k. Anybody have this problem aswell? Or have an idea of what the problem is?
Old Apr 10, 2014 | 06:44 PM
Default Re: Idle issues
Vacuum line come loose?
Old Apr 10, 2014 | 08:14 PM
matth189's Avatar
No vacuum lines loose that I can see. Also I changed the front six spark plugs yesterday, would that have anything to do with it?
Old Apr 10, 2014 | 08:52 PM
Cables hooked up tightly on the plugs?
I do not believe in coincident problems like this too much.
Old Apr 10, 2014 | 08:53 PM
Damaged plug?
Old Apr 11, 2014 | 12:15 AM
matth189's Avatar
Now it's throwing a p0101 code
Old Apr 11, 2014 | 08:13 AM
Follow this thread to the next thread.
Old Apr 11, 2014 | 12:46 PM
matth189's Avatar
180 thank u so much for the help, really appreciate it. So if the MAF is the faulty part is it possible to buy just the sensor or do they all come with the housing?
Old Apr 11, 2014 | 12:53 PM
matth189's Avatar
Also is this the correct Bosch part number? 0280217515
Old Apr 11, 2014 | 01:13 PM
The sensor should have a number on it - Bosch? The number you list is the whole assembly. You only want the sensor itself, do not let them tell you that you want the whole thing.
You may get results with spraying the sensor with MAF cleaner, it worked before.
Maybe you can just buy the sensor, I do not know, just do not buy it from Chrysler or Mercedes when you have the part number.
I cannot say what is actually wrong.
Old Apr 11, 2014 | 01:20 PM
SRQfun's Avatar
Make sure that you got the engine cover back on correctly. Jack's Red Racer was having an idle issue and it was just the cover was not set on tight. Reset correctly and the car was back to racing
Old Apr 11, 2014 | 02:22 PM
Padgett's Avatar
By any chance do you have a K&N air filter and did you clean/oil it ? Have heard of the oil clogging a MAF and, if so cleaning fixed.
DO NOT use carb cleaner, it can damage the sensor. There is a MAF cleaner at most FLAPS.
Old Apr 11, 2014 | 08:00 PM
matth189's Avatar
No I do not have k&n filters, and I just checked all the spark plug boots and the engine cover. Still not fixed. Not sure what to do next. I do not want to take it to a shop here in tucson because I do not know of one I can trust
Old Apr 29, 2014 | 08:25 PM
matth189's Avatar
Hey just wanted to let everyone know the fix was a new Bosch MAF. Installed it today, cleared the cel, and it drove amazing again! Thanks again for everyone who responded.
Old Apr 29, 2014 | 08:34 PM
SRQfun's Avatar
Glad to hear!!! Now enjoy the driving
Old May 2, 2014 | 02:15 AM
dom03's Avatar
Just a heads up to the OP, I had the exact same issue and was resolved by getting a new bosch MAF, however few months later car was running lean again and experiencing same symptoms (idle between 2-3k fluctuate, and car shutting off, and not starting properly.)
I ended up having to order another MAF but got the official OEM Bosch one from mopar $450!!!
rampntlion
21
Feb 11, 2019 08:18 AM
Reliableron
Oct 17, 2015 10:19 PM
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
bobbie
Sep 12, 2015 12:49 PM
MickeyNasty
Sep 6, 2015 08:29 PM
