Alternative to connecting DRL directly to Battery?
Old Aug 1, 2014 | 09:55 PM
Danwell's Avatar
Default Alternative to connecting DRL directly to Battery?
I'm in the process of adding some Daytime Running Lights (Philips Daylight 8) and it says to hook the lights directly to the battery, but isn't there a way to just go connect to the fuse block & frame??
I can connect to the fuse block by using a fuse tap like the bottom one on this page.
http://www.littelfuse.com/~/media/fi...fhm02fha02.pdf
Old Aug 1, 2014 | 10:02 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Alternative to connecting DRL directly to Battery?
You will find the info for the perfect spot to connect here: https://www.crossfireforum.org/forum...tml#post645463
Old Aug 1, 2014 | 10:25 PM
Danwell's Avatar
That's some cool info you got there. I'm checking it out now & Thanks, Sparkie
Old Aug 1, 2014 | 11:39 PM
deltacrossfirebob's Avatar
Danwell
I followed sparkiesrt6 info and it worked great.
SparkieSrt6 did a great job on his directions.
Have had mine for over a year now with no problem.
Thanks SparkieSrt6.
Follow them.
Old Aug 2, 2014 | 08:53 AM
Originally Posted by deltacrossfirebob
Danwell
Thanks SparkieSrt6.
Follow them.
Thank you Bob.
Old Aug 2, 2014 | 10:10 AM
Danwell's Avatar
Yes, I'm really liking the info Sparkie put on here. It's so cool to have that post in the Fuse Block that comes live when switch is on.
Old Aug 2, 2014 | 01:20 PM
syfi's Avatar
I use these for DRLs. Osram LED Light@Day. Most impressive looking DRLs I could find. Dimmable. A single very bright LED shoots sideways through an advanced reflector giving the lamp the illusion of a single light bar with absolutely uniform light distribution, unlike the average DRLs with 5 or 6 LED spots showing. Type Osram LED Light@Day in Google for YouTube vids and the like. They used to be sold only in Europe but I noticed that AutohauzAZ now stocks them!!
LIGHT@DAY | LED daytime running light | OSRAM
http://www.autohausaz.com/search/pro...B0gaAvXf8P8HAQ
Old Aug 2, 2014 | 04:23 PM
Danwell's Avatar
They look nice Syfi. They are about the same size as the Philips from what I can tell from the photos.
I think I'll like the Philips just fine, but I really wanted longer ones as the Crossfire could fit longer one's but just couldn't find any except maybe those cheapo ones on Ebay for like 10 dollars and such.
The Philips (and Osram) look OEM which is good so it won't look cheesy or ricer. I will be mounting mine a bit above where you put yours and connecting to the bumper.
rmcdaniel12
Sep 22, 2015 01:20 PM
tritongreen
Sep 18, 2015 07:32 AM
skeet370
29
Sep 18, 2015 05:53 AM
Valk
Sep 17, 2015 11:43 AM
RiderJC
Sep 7, 2015 11:19 PM
