Windshield washer problems
Old Feb 1, 2005 | 11:03 AM
FULLDRAW's Avatar
Default Windshield washer problems
This past weekend my washer would not spray so I figured it was just out since I have never added any. I stopped and got a gallon and it just kept taking and taking it until I noticed it was running out from under the car. I have it scheduled for the dealer tommorrow but was just curious if any of you guys have seen this? thanks Mike
Old Feb 1, 2005 | 11:25 AM
saldous's Avatar
Default Re: Windshield washer problems
Known issue. On the cover of the washer fill-up bit under the bonnet it does say not to over fill it.
Old Feb 1, 2005 | 11:46 AM
C_Plunkett's Avatar
If it wouldn't spray to begin with, it's probably not overfilled. My guess would be that the hose connected to the reservoir came loose allowing the fluid to drain out.
Old Feb 1, 2005 | 08:39 PM
rick333's Avatar
The fluid you saw running under the right side of the car was the overflow. The way the neck of the almost two gallon container is constructed, you could not see when it is full in time for spillage on the MB engine compartment.......heavens. The overfow tube is designed to keep the fluid out of the engine bay.
Since your addition of a mear on gallon produced an overflow, I would suspect that you either have a clogged line or the electrics aren't hooked up or the pump motor is bad.
Old Feb 4, 2005 | 01:26 PM
FULLDRAW's Avatar
Just to update on this problem. The day I was taking it in for service I tried the washer and it worked fine but I still thought it may be cracked so I took it anyway. The service guy stated it was fine and it also was full so what must have happened is the hose or the nozzles were froze and I just thought it may be empty since I had never added any. I did not know it holds 7.5 quarts! The service manager says there is a overflow that it runs out of if someone tries to overfill it. I guess that is exactly what happened. Just thought I would relay this back since it may help someone in the future. Mike
Old Feb 4, 2005 | 04:30 PM
brittt1's Avatar
Isnt the windshield washer fluid holder supposed to be heated in the Xfire? if yes then sounds like you still have a problem....Im sure I read that the widshield washer fluid is heated to keep it from freezing......i'll hunt it out...
btw, where did you buy your Xfire? Im in Alexandria and in dire need of a good dealer i can trust.
Old Feb 4, 2005 | 04:36 PM
brittt1's Avatar
actually it looks like only the nozzles are heated
from the Chrysler crossfire website, 'limited' feature:
'Heated exterior mirrors and washer nozzles'
I guess you just need to get some good anti-freezing washer fluid and the nozles will do the rest :-)
Old Oct 8, 2018 | 11:01 AM
cartoonguy2002's Avatar
My windshield wiper fluid went dry on my way to the airport, so it say for a week dry. I think it crusted over. I removed the nozzles and they are soaking in vinegar. Never let them put water in the reservoir, you gotta stop them during your oil change or they'll do that.
There are electrical wires going to the nozzles, wtf? These people never heard of "Keep It Simple Stupid"
Old Oct 8, 2018 | 11:38 AM
A bit of thought on the nozzle hearers is required to get the point of them. Did you take the nozzles apart as the problem maybe behind the jets?
Old Oct 11, 2018 | 07:38 PM
I got the nozzles off, soaked them in vinegar for a couple hours, then put the whole thing back together. It works ok. the drivers side doesn't squirt that well, but it works.
Old Oct 11, 2018 | 09:12 PM
You have to take the ball nozzle out of the nozzle housing to clean it properly and then pump fluid through the lines to clear out any junk in them. Run a fine wire through the nozzle jet hole.
oldbiff
Mar 19, 2023 11:37 AM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
Vegaslegal
Sep 10, 2015 11:24 AM
williammt
Sep 6, 2015 11:23 AM
