brake replacement
Old Jul 21, 2015 | 12:45 PM
Rooster98's Avatar
Default brake replacement
hello,
need to replace my brakes, and would like to hear any recommendations regarding upgrade from standard to performance.
regards,
rooster
Old Jul 21, 2015 | 09:21 PM
RyanB's Avatar
Default Re: brake replacement
Do you have a limited? I think the easiest/cheapest upgrade is to change them over to SRT-6 brakes. I do not know for sure, but I think all calipers are larger (I know the back are).
StopTech makes a kit as well that needswings sells: StopTech Big Brake Kit Front
If you are just hunting for brake pad recommendations, I have a limited and I am very happy with the Akebono Ceramic (less brake dust). I put Brembo blank rotors along with the pads and do not have any issues with the stopping power.
Old Jul 22, 2015 | 06:23 AM
I put EBC "Red Stuff" pads on 3 years ago and have not looked back. Very low dust, little wear, no noise and stops on a dime.
( also the backing plates are red, which matches my red painted calipers )
Amazon.com: EBC Brakes DP31193C Redstuff Ceramic Low Dust Brake Pad: Automotive Amazon.com: EBC Brakes DP31193C Redstuff Ceramic Low Dust Brake Pad: Automotive
Old Jul 22, 2015 | 09:06 AM
Rooster98's Avatar
I do have a limited. this information is very useful.
thank you guys
Old Jul 22, 2015 | 02:13 PM
xzmilan's Avatar
Thanks for the link! I also have red calipers and this is a good option for pads. The link was to another version...not for an 04 crossfire at least.
For the 2004's like mine this is the model you want for the Redstuff. EBC Brakes DP31075C Redstuff Ceramic Low Dust Brake Pad..
and link.
Amazon.com: EBC Brakes DP31075C Redstuff Ceramic Low Dust Brake Pad: Automotive Amazon.com: EBC Brakes DP31075C Redstuff Ceramic Low Dust Brake Pad: Automotive
Old Jul 22, 2015 | 05:15 PM
IGot2P's Avatar
While on the subject of brakes, do any or all of you get more brake dust on the front wheels that the back? I know that I certainly do.
Don
Old Jul 22, 2015 | 07:44 PM
RyanB's Avatar
Yes, I don't know what brand were installed when I bought the car, but the front wheels would stay clean for about 2-3 days before being covered. I read an older thread on here and everyone recommended ceramic brake pads to reduce/eliminate brake dust. This is the first vehicle I have used ceramic pads on - but it made a huge difference. I rarely go longer than 7 days without washing my car, but you notice the body getting dirty before the wheels now.
Old Jul 22, 2015 | 11:14 PM
JEFASOLD's Avatar
The Hyper ceramix pads by DiscItalia from BrakeWorld are the best pads I've ever used.
Old Jul 31, 2015 | 03:22 PM
Goldwing's Avatar
Any premium ceramic will be low-dust and stop well. You might have some chatter though. You can buy solid rotors or, if you like the looks, slotted and/or drilled. Google is your friend. I went with standard solid when I replaced them on my SRT6. It is not worth swapping in a high performance kit unless you are seriously racing. Good rotors and pads will more than stop you. If you want fancy, paint the rotors.
Yes, it seems all German cars spit more brake dust on the fronts than the rears. That's why I always swap out stock for low-dust. Even did it when I bought my 2011 A4 2.0T used, which had brand new pads all around. Out they went for Disc-Italia.
Old Dec 23, 2015 | 08:46 PM
gp1200x's Avatar
Anyone try the new Disc Italia Titanium Kelvar pads? Have a 2004 stick with 43K and I think its time for new pads and rotor turning. It will be either these, their ceramic ones or the Red Stuff pads. I'm thinking the Kelvar may have more stopping power but harder on the rotors.
Old Dec 23, 2015 | 09:13 PM
boostmonkey's Avatar
Default
I have the EBC Redstuff on my SLK32 and Greeenstuff on my daily. They are my favorite brake pads I have ever owned. I am very picky about brake pads too. The Redstuff pads squeak sometimes under light pressure when cold. The friction level is very high across a very broad range of temperatures.
Old Dec 24, 2015 | 08:12 AM
Same here, Redstuff on the Crossfire, Greenstuff on the Concorde Limited ....
Old Dec 24, 2015 | 10:06 AM
Goldwing's Avatar
I put Disc Italia Kevlars on my SRT6 at 8500 miles (currently just over 30k) and they work fine. No unusual rotor wear. I have them on the fronts of my roadster and, as mentioned, fronts of my 2011 A4. Very low dust. They stop fine, but I'm not tracking any of them.
Old Dec 24, 2015 | 10:59 AM
JEFASOLD's Avatar
I have DiscItalia hyper ceramix and I think they are great.The best I have had, no dust at all and super stopping power.
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
northwest_crossfire
May 30, 2016 05:19 PM
Romio
Jul 24, 2015 07:04 AM
Rooster98
Jul 21, 2015 12:39 PM
