Terrible Day!
Old Feb 2, 2005 | 02:10 PM
Rob M's Avatar
Default Re: Terrible Day!
Originally Posted by saldous
I'm not sure how well these work on a performance low profile tyre like we have though. I've be wary of a plug at high speeds. If something happend would your insuance pay out if it was caused but this?..
they'll work just as well as on any other tire. but if you were racing or constantly driving and cornering at high speeds you'd want to replace the tire. and if you're worried about it holding you can always get it checked out later and patch it or replace it.
there's lots of debate, even among tire shops and dealerships related to repairing punctures in tire treads. some shops won't repair any tires because they want you to buy a new tire from them. others will only do an off the wheel repair patch from the inside for $25 or so. and some will still plug the tire while still on the rim. i've had several tires plugged in the past and none have ever failed. i don't know any one who has personally had a tire plug fail. i'm not saying it can't happen. but if it does fail what will happen? most likely the tire just goes flat again.
the plug method though really is something that should be reserved primarily for roadside repairs. a patch technically will be better because it can be tricky to follow the hole all the way through the tire while plugging. also keep in mind that a plug may invalidate your tire warranty. on the other hand tire warranties are like brake pad wrranties and don't really mean a whole lot.
as far as insurance is concerned, auto insurers (in the u.s.) would provide coverage in the event you had an accident even if it a failed tire plug was the culprit.
Old Feb 2, 2005 | 02:24 PM
CyberGreg's Avatar
Don't know about the 19" tire... This runflat system would be cool to get, my guess is its pricey, but then again a blowout at 80+ is gonna hurt, big time.
Click for Linkage
Old Feb 2, 2005 | 03:29 PM
Bob G's Avatar
Originally Posted by CyberGreg
When you guys are talkin' donut, are you referring to a steel rim with small tire that you can drive safely up to 50 MPH and for like 50 miles? Sometimes refered to as a space saver tire? Would you put it in the back? I'd make sure I had that rear cover installed so no one would see it!
I do understand about the tire pressure monitor but man if someone could make an inner tube that would fit and work in these tires, I'd buy two! I'm sure a tube could be made, so that in an emergency you could drive the car a few hundred miles, or several days. Hopefullly enough time for the replacement tire(s) to arrive. I don't think its a problem for an inner tube to safely function, heck tractor trailers use tubes and I'm sure they see more stress and weight than what a Crossfire would need or use. I do understand the concerns about the rim, I don't think it would be a problem given todays mfg processes and the fact that you have to slide the tire over the sides to install it. I know real "wire" wheels have this problem (all it takes is a rubber band to remedy it) but I don't think "alloy" wheels would.
If its a choice between a donut and the fix-a-flat, I'll take the fix-a-flat and call AAA when and if I have a problem.
Hmmm thinking back to my youth, I think if you packed three or four tire "spoons" (whatever they are called!) you could install the tube yourself and pump up the tire with the air pump!
Cyber:
I think a tube is not the best option because of: 1) If you are carring a spare tube in your car you still have to get to a garage to get it installed. 2) You have to replace your senor with the tube stem as they use the same hole. 3) It will be pretty hard to find a low profile tube to fit 4) If you are thinking of running a tube all the time, it will still get a flat when your tire punchers 5) Again there may be purs on the rim that could cut the tube.
Run flats sound interesting though.
Old Feb 2, 2005 | 04:33 PM
buckeyedad42's Avatar
has anyone found a doughnut with a lug pattern to match the Xfire? I would get one and put it in the trunk of the xfire (roadster) if it fits. The trunk isn't good for anything else. and would give me piece of mind on the road. Although I don't know if my wife could hold the 19" rim and flat tire in her lap(lol)
Old Feb 2, 2005 | 04:36 PM
CyberGreg's Avatar
Hey Bob G,
Yeah, I hear yah... I was really just thinking that a tube "might" be like an emergency use type option. Say I'm mid-drive to Vegas and get a cut in the sidewall. First if I didn't have a wreck, that would be great, second I'd be in the middle of friggin' nowhere so once I got flatbeded to some garage I could "whip out" my tube and have them install it and be on my way. Then in a few days have the tube removed and the tire replaced. Again this is if it were a problem with the sidewall. If its a puncture in the tread, no problem as I'll have one of those tire plug repair kits in my car before the weeks end!
Old Feb 2, 2005 | 05:56 PM
Bob G's Avatar
Originally Posted by buckeyedad42
has anyone found a doughnut with a lug pattern to match the Xfire? I would get one and put it in the trunk of the xfire (roadster) if it fits. The trunk isn't good for anything else. and would give me piece of mind on the road. Although I don't know if my wife could hold the flat 19" rim and tire in her lap(lol)
OH YEAH! I didn't even think of what to do with the tire after it is changed. Now I'm depressed! Back to run flats!
Old Feb 2, 2005 | 08:16 PM
bob G, read a review while back with the design engineers about the lack of spare on the xfire and the DC engineer said they tried run flats but that they made the ride lousy so they dropped that idea. Get a repair kit and pray a lot!
Old Feb 2, 2005 | 10:19 PM
Bob G's Avatar
Had the plug kit when I bought the car! I always had one in my Lexus, just in case.
Old May 17, 2006 | 01:04 AM
Eddy's Avatar
I had a flat on the freeway on the weekend, took the sidewall out at 60 mph, the tire was ruined by the time I stopped the car. Having experienced that, I found the 19" will NOT fit in the trunk, I will be adding a plug kit after paying the tow bill and replacing the tire, I will be keeping a spare rubber in the garage as I refuse to pay $450+ dollars for a tire at the local shops, (I was offered 1 for $750.00 in 2 days...lol). I will be ordering from tirerack really soon.
Old May 17, 2006 | 07:57 AM
FarbenKiber's Avatar
The thought of not having a spare creeps into my head whenever I'm on a long road trip. I have the best plug kit I could find, but if I get too severe a puncture I'm screwed. It doesn't help that I'll bet not many tire shops have our sizes in stock.
Who has a nice CNC machine? We can crank out some custom spares.
Old May 17, 2006 | 08:11 AM
andrew's Avatar
-C-I-C-C-I Associate Member
this is what i carry in my trunk just in case.
cost about $10... cheap insurance imo.
i used one on my M3 in the past... worked great. plugged a small hole on the side of the road... used the factory compressor and i was on my way. no issues with the plug or tire for the remain life of the tire.
~ link to purchase online:
http://shop.store.yahoo.com/bradysto...remtireki.html
aptiva's Avatar
I have to admit that when I bought my car, I had a huge knot when I found out there was not a spare. I thought for sure that Chrysler could have included one of those uninflated donuts for an emergency. Like everything else for this vehicle, I doubt if anyone makes that type of donut that would fit this car. I do carry a repair kit, and all the tools necessary to plug a hole, but like one of the previous posts said, it would have to be a "normal" type flat, no sidewall damage etc. I know for a fact that if an uninflated spare were available, it would be in my trunk. If anyone knows if one exists, please post it.
Old May 17, 2006 | 10:54 AM
aptiva's Avatar
I just read in another forum that the Mercedes SLK comes with a collapsible tire. I wonder if the lug pattern is compatible.
Old May 17, 2006 | 05:14 PM
Irafatsar's Avatar
AAA+ 100 MILES TOWING. DONT LEAVE HOME WITH OUT IT. I HAVE BRITISH CARS MG'S, HEALEYS, MINI COOPERS. I DON'T WORRY ABOUT TIRES AS MUCH AS ELECTRICAL PROBLEMS. GOTTA LOVE LUCAS.
SORRY FOR YELLING I have turned off the cap locks.
Osusannah
Feb 12, 2024 01:49 PM
franklindm
Mar 14, 2020 12:23 PM
o55ie18
Oct 5, 2015 05:50 PM
ozkancab
Sep 25, 2015 10:55 AM
Abaton6
Sep 24, 2015 10:14 PM
