Tranny popping out of gear AGAIN!?
Old Feb 8, 2005 | 08:07 PM
dirtboy's Avatar
Unhappy Tranny popping out of gear AGAIN!?
Less than a year ago I bought a new 04 6sp Crossfire and right away it developed the infamous popping out of first gear problem. After much hassle a new transmission solved the problem.
Today I was driving home from an appointment only to have it pop out of gear again. Thinking this might be a fluke or a mistake on my end, I ignored it. Three stoplights later it did it again.
Just curious to see if anyone else who had this problem initially has had it redevelop. My car doesn't even have 8,000 miles on it yet.
Old Feb 9, 2005 | 01:22 AM
Bullseye's Avatar
Default Re: Tranny popping out of gear AGAIN!?
But doesnt the car handle great though? I mean wow, the handling it is crazy.
I have run into that problem also, as many of us have. Has good build quality though.
Old Feb 9, 2005 | 07:44 AM
Steffen's Avatar
Thats why nobody drive the car here in Germany without auto! Everybody now that Mercedes (now Chrysler too) build the badest manuals!!
Old Feb 9, 2005 | 08:08 AM
saldous's Avatar
Exactly, mine is Auto as I know that MErcedes does not do good manuals.
Old Feb 9, 2005 | 09:10 AM
TSaxMan113's Avatar
My '05 pops out of first once in a while as well. It pisses me off, but the dealer was unable to replicate the problem so they won't look into it.
Old Feb 9, 2005 | 10:12 AM
slide93's Avatar
The original TSB for that issue (21-002-04) has been superceeded with a new "advanced notice" TSB (21-005-05) published on 2/05/2005 and is supposed to take affect on 2/14/2005. Supposedly the reason is because a special tool is required for reassembly of the transmission, which will not be available to the dealers until 2/14.
In addition to the gear synchronizer issue, this bulletin recomends that first the dealer should adjust the reverse lockout cable to resolve the issue. Apparently if it is not adjusted properly the transmission will pop-out of first gear because it thinks you are trying to lift up to engage reverse.
Take it to the dealer and refernce that TSB. They should adjust the reverse lockout cable and if the problem persists have them try the gear synchronizer fix after they have acquired the tool (9204) to do the job properly.
I had the lockout cable adjusted this week but haven't driven the Crossfire enough to see if the problem still exists.
Good Luck!
Old Feb 9, 2005 | 01:08 PM
dirtboy's Avatar
Thanks slide93!
syfi
Mar 28, 2026 04:14 PM
crossfireusa
Oct 28, 2015 12:03 AM
Blackktieguy
21
Oct 26, 2015 12:32 AM
jimf
Oct 10, 2015 10:22 AM
rfourt
Sep 25, 2015 01:38 PM
